    Servos working on wrong axis
    3 Posts 2 Posters 1.1k Views 2 Watching
    • ashscottA Offline
      ashscott
      I'm placing a servo in a model and no matter what I do it only works along one axis....regardless of where I set the servo's axis.
      I have rebuilt all geometry around the servo and placed the servo on every angle imaginable and it still operates on an axis perpendicular to the one I want it to.
      Has anyone encountered this before?
      Ash
      Just some stuff I do with Sketchup.
      • chriC Offline
        chri
        hi ashscott
        Can you send a skp file and perhaps an hardcopy , please ?
        chri
        • ashscottA Offline
          ashscott
          As is often the case with geometry errors in SP I exploded every bit of geometry within a certain radius of the problem joint (including geometry it was not attached to) and re-grouped it all. It took some time but the problem is solved...
          Thanks for the attempt to help Chri
          Note to anyone else with these kinds of problems - explode EVERYTHING to base level and regroup.
          Ash
