    Two motors with different rotation
    8 Posts 3 Posters 1.6k Views 3 Watching
    • SantusS Offline
      Santus
      Hi, I would like to create a simple logo where inner part should rotate counter clockwise and outer part clockwise. I already have joints and they are moving, problem is that they are moving with the same speed. In UI control I can see two different slides to control their speed but they seems to be connected i.e. if I move with motor1, it will affect also motor2 and opposite.
      I've tried to put each component into separate layer but it didn't work.
      I checked almost all tutorials but still I'm more than desperate :]
      Any help/hint is more than welcome.
        Best hint is to post your Skp file πŸ˜‰
        • SantusS Offline
          Santus
          Here it is πŸ˜„
          Ingr.draft.skp
          • SantusS Offline
            Santus
            Santus FTW! In UI setting select for second object (not for motor) parameter State to "nocolision" and then it will do desired effect :]
              β˜€ πŸ‘
              • chriC Offline
                chri
                hi Santus
                Well
                Can you send a picture
                I don't understand where your turn the parameter to nocolision !
                thanks
                chri
                • SantusS Offline
                  Santus
                  Hi chri,
                  in my case I have sketchyphysics version 3.2 and if you will follow this, you should get the same result i.e. two speed controls after you click on play and they aren't connected, you can control speed (only speed, not direction of rotation). I did couple of changes in my file and outer part is rotating differently. Anyway, principle is the same πŸ˜‰
                  http://pixelarium.cz/cyber/sketchup/SU.Phys.Motors.Tut.jpg
                  FullSize: http://pixelarium.cz/cyber/sketchup/SU.Phys.Motors.Tut.jpg
                  Hope that helped πŸ‘
                  Cheers!
                  Check this attachment, new version and working rotation... IMO depends on version of physic probably
                  Version 0.2
                  • chriC Offline
                    chri
                    hi SANTUS
                    Very clear
                    i have downloaded your new file .
                    he don't works with skectchyphysics 3-1
                    We need at least 3-2 beta
                    the important things we have learn today is that skecthyphysics 3-2 allow us to use NOCOLISION , and i think , it's very useful .
                    thanks for your help and your quick answers
                    chri
