    Help with transformation
    14 Posts 3 Posters 764 Views 3 Watching
      Davidfi1
      Hi Guys
      I need some help using the correct Geom::Transformation.
      My task is to place a component and scale it's x axis, between two points.
      I need to figure out what is the Geom::Transformation needed for
      the add_instance method.
      Geom::Transformation.scaling xscale, 1, 1 will do the scaling
      Geom::Transformation.axes startPoint , xaxis, yaxis, zaxis
      moves the component to the first point and changes its axis
      How do I combine the transformations and what do I need to use for
      xscale, xaxis, yaxis, zaxis?
      Thank you
      David.
      • Dan RathbunD Offline
        Dan Rathbun
        It would be easier to just place the instance at the desired insert point, and then afterward apply the non-uniform scaling transform.
        Within some method:
        ipoint = Geom;;Point3d.new( x, y, z )
        tp = Geom;;Transformation.new( ipoint )
        ts = Geom;;Transformation.scaling( xscale, 1.0, 1.0 )
        inst = ents.add_instance( defn, tp )
        inst.transform!( ts )
        I'm not here much anymore.
          Davidfi1
          Dan, what did you say about the second point?
          I need to rotate the new component's x axis to be in line with the two points.
            Dan Rathbun
            OK.. gotcha.
            You also need a y-axis vector
            def place_and_tweek( defn, pt1, pt2 )
              xvec = pt1.vector_to( pt2 )
              yvec = xvec.axes[1] # ???
              tp = Geom;;Transformation.new( pt1 )
              ts = Geom;;Transformation.scaling( xvec.length, 1.0, 1.0 )
              ta = Geom;;Transformation.new( pt1, xvec, yvec )
              inst.transform!( ta )
              Davidfi1
              OK - I finished πŸ˜„ I think.
              This is what came out:
              def add_Filament( startPoint, endPoint , filament )
                    @lineVector = startPoint.vector_to endPoint
                    return if @lineVector.length.to_f - 1e-6 < 0.0
                    # Scaling and adding an instance of the filament
                    @scale      = @lineVector.length.to_f / filament.bounds.height   #width #depth
                    @trans      = Geom;;Transformation.scaling 1, @scale, 1
                    @instance   = Sketchup.active_model.active_entities.add_instance( filament, @trans )
                    # if needed rotate the filament
                    @lineVector.normalize!
                    @instYaxis  = Geom;;Vector3d.new( 0, filament.bounds.height, 0 ).normalize #height givs the Y axis
                    @rotDeg     = @instYaxis.dot( @lineVector )
                    @rotDeg     = Math;;acos( @rotDeg )
                    if @rotDeg.to_f - 1e-6 > 0.0
                      if @rotDeg.to_f + 1e-6 > Math;;PI
                        @rotVector = Geom;;Vector3d.new( 0, 0, 1 )
                      else # if PI
                        @rotVector = @instYaxis.cross( @lineVector )
                      end # if PI
                      @trans       = Geom;;Transformation.rotation( ORIGIN, @rotVector, @rotDeg )
                      @instance.transform!( @trans )
                    end # if @rotDeg > 0.0
                    # Moving the filament to the startPoint
                    if not ( ORIGIN == startPoint )
                      @trans       = Geom;;Transformation.new startPoint
                    end #if not ORIGEN
              • sdmitchS Offline
                sdmitch
                David, You did a bit more work than was required. The entire section regarding rotation is not needed. You only need to add ", @lineVector" to the last Transformation
                        @trans    = Geom;;Transformation.new startPoint, @lineVector
                      end #if not ORIGEN
                http://sdmitch.blogspot.com/
                  Davidfi1
                  Do I need to do the checking ORIGIN etc..?
                  Or it should be:
                     # Moving And Rotating the filament to the @lineVector
                  end # def add filament
                  P.S - Why filament.bounds.height is the length of the Y axis of the component?
                  I thought height is the Z axis - no?
                  • sdmitchS Offline
                    sdmitch
                    No you don't need the ORIGIN check. Since you don't specify a location when adding the instance, it is by default placed at the origin.
                    I agree, you would think height would be Z but no, bounds.width=X,bounds.height=Y, and bounds.depth=Z.
                    Doing the scaling when adding the instance is something I had never thought of so I learned something too.
                      Davidfi1
                      hhh - doesnt work πŸ˜„
                      All our work for nothing
                      • sdmitchS Offline
                        sdmitch
                        Why doesn't it work? How is it failing?
                        Provide screen shots or sample model.
                        How the component is made and the axes defined will always determine how it orients when placed.
                          Davidfi1
                          Well, In the documentation it says that if the second parameter is a vector
                          It will be used as a Z axis - this is what is happenening!.
                          Quote:
                          Geom::Transformation.new(origin, zaxis) creates a Transformation where origin is the new origin, and zaxis is the z axis. The x and y axes are determined using an arbitrary axis rule.
                          • sdmitchS Offline
                            sdmitch
                            That's why I mentioned how the orientation of the component when created would be critical. If you could post a model with the component in it would make it much easier to figure out what you need to do to correct the problem. Just a wild guess but try this
                            		xa,ya,za=@lineVector.axes
                            		@trans  = Geom;;Transformation.new xa,za,ya,startPoint
                              Davidfi1
                              Thank you.
                              I will post the G-Code importer I am workin on soon
                              Then you could play with it and see if it is possible to make the original code more elegant.
                              The code I posted works!. It is a little ... well ... not very elegant - but it works πŸ˜„
                                Davidfi1
                                Posted the first vertion of the importer at
                                http://sketchucation.com/forums/viewtopic.php?f=323&t=50067
