    Find the position of a group in the active context
    6 Posts 2 Posters 509 Views 2 Watching
    • D
      dacastror
      Hi, I'm trying to find the position of a group in the active context, relative to the coordinate system of the group that it contains (which itself can be contained within other groups), this picture illustrates the situation
      https://sites.google.com/site/dacastror/archivos/coordenadas.jpg
      You may also need to do this but with components. Really, I do not find the way to accomplish what I need, I appreciate your help
      (google translator)
      • sdmitchS
        sdmitch
        A recent discussion might help
        http://sketchucation.com/forums/viewtopic.php?f=180&t=49592
        http://sdmitch.blogspot.com/
        • D
          dacastror
          thanks for replying, I saw this link, unfortunately I still do not understand how to solve my problem
          • sdmitchS
            sdmitch
            The transformation of a sub-group will be relative to its parent so the sub-groups.transformation.origin will be the dx,dy,dz relative to the container group.
            For example your model contains a group which contains another group then the following code would find the most embedded group and output its transformation.origin to the Ruby Console.
            mod = Sketchup.active_model
            ent = mod.active_entities
            sel = mod.selection
            grps=[];tran=[]
            grps<<ent.grep(Sketchup;;Group)[0]
            tran<<grps[0].transformation
            begin
             fnd=false
             grps[-1].entities.each{|e|
              if e.class==Sketchup;;Group
               grps<<e;tran<<e.transformation
               fnd=true;break
            end while fnd
            puts grps[-1].transformation.origin
            • D
              dacastror
              Sdmitch thank you very much, unfortunately the problem persists when I'm in the active context, I'm trying something with this
              path = mod.active_path
              tr1 = Geom;;Transformation.new([0,0,0],[1,0,0],[0,1,0])
              if path
                path.each{|entity|
                   tr2 = entity.local_transformation
                   tr1 = tr1*tr2
              tr1.origin
              It works, but to play around with this in the least expected moment this fails. If it always worked, I would do something like this then
              sel = mod.selection
              if path
                path.each{|entity|
                   tr1 = tr1*tr2
              origin_parent = Geom;;Vector3d.new(tr1.origin.to_a)
              ejex_o = sel[0].transformation.xaxis
              ejey_o = sel[0].transformation.yaxis
              center = sel[0].local_bounds.center
              tr3 = Geom;;Transformation.new([0,0,0], ejex_o, ejey_o)
              center_tr = Geom;;Vector3d.new((center.transform tr3).to_a)
              origin_group = Geom;;Vector3d.new(sel[0].transformation.origin.to_a)
              point = origin_group - origin_parent + center_tr
              point_tr = point.transform tr1.inverse
              here I have gained the center of the group with respect to the coordinate system of the parent in the active context. The problem is that it only works well sometimes,
              I do not understand how to fix this
              (google translator)
              • D
                dacastror
                I solved the problem, the key was to use "mod.edit_transform.origin"
                I leave the code in case anyone needs it one day
                mod = Sketchup.active_model sel = mod.selection parert_origin = mod.edit_transform.origin entity_origin = sel[0].transformation.origin distance = entity_origin-parert_origin tr = mod.edit_transform.inverse distance.transform tr
                šŸ˜„
