    Will this work on Mac OS?
    4 Posts 3 Posters 326 Views 3 Watching
    • N
      niccah
      Hey at all!
      A first release of my plugin comes closer and closer, but I have no possibilities to check my code on Mac OS... To avoid very basic problems, I would like to ask you: What do you think? Will this code work?
      ` fileContent = "Java -jar " + File.dirname(FILE) + "\Model2GCode.jar"
      fileName = File.dirname(FILE) + "\Model2GCode."
      fileName << "command" if (RUBY_PLATFORM.downcase.include?("darwin")) # Mac OS
      fileName << "bat" if (RUBY_PLATFORM.downcase.include?("mswin")) # Windows
      file = File.new(fileName, "w")
      file.write(fileContent)
      file.close
      UI.openURL(File.dirname(FILE) + "\Model2GCode.bat") if (RUBY_PLATFORM.downcase.include?("mswin")) # Windows
      UI.openURL(File.dirname(FILE) + "\Model2GCode.command") if (RUBY_PLATFORM.downcase.include?("darwin")) # Mac OS`
      @Thom: You wrote a nice post, at which you explained, at which code parts one has to be careful because of the differences between Win / Mac. Could you please give me a link to this post? I could not find it anymore πŸ˜’
      Thanks for your help!
      • N
        niccah
        @aerilius said:
        File.join("folder1", "folder2", "filename")
        Oh yes, you are right! This is the next point on my list. However, thanks a lot for the hint!!!
        OSX = ( Object::RUBY_PLATFORM =~ /(darwin)/i ? true : false ) unless defined?(OSX) WIN = ( not OSX ) unless defined?(WIN)
        This looks very smart! Thanks!! πŸ˜„
        • A
          Aerilius
          first, backslashes are a relict from when Windows did not need to support nested folder structures. File path delimiters differ between operating systems and because of that Ruby has super cool abstracted methods to deal with that, ie.
          [File.join](http://www.ruby-doc.org/core-1.8.6/File.html#method-c-join)("folder1", "folder2", "filename")
          So it is best to clean up a file path immediately when you receive it (from the UI etc.):
          ` # This resolves relative paths and symbolic links and makes sure all delimiters will be later the same.
          path = File.expand_path( File.dirname(FILE) )
          This joins the paths.
          filename = File.join(path, "Model2GCode.")`
          In order to avoid repetition, you can define operating system constants once:
          ` OSX = ( Object::RUBY_PLATFORM =~ /(darwin)/i ? true : false ) unless defined?(OSX)
          if WIN
          do_something
          elsif OSX
          do_something_else
          end`
          For the rest, I have to leave the field for actual OS X users.
          • D
            driven
            hi,
            you may need a java version test, as mac no longer ships with it pre-installed, it does however recomend installing as part of the start-up sequence.
            so, from ruby console
            java_version=(`java -version 2>&1`).split("\n")[0].to_s.split[-1]
            "1.6.0_37"
            john
