    โš ๏ธ Attention | Having issues with Sketchucation Tools 5? Report Here
    Group in a group in a group... - transform point to outside?
    25 Posts 6 Posters 2.4k Views 6 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      It is not advisable to use UI.messagebox() for debugging. (If the string argument is invalid, then UI.messagebox() either fails silently, or causes a error by itself.)
      Use puts() to output inspection strings to the Console instead.
      I'm not here much anymore.
      • sdmitchS Offline
        sdmitch
        I tried to simulate your problem using the code you posted but I got 0,0,0 points for some of the faces as expected.
        Perhaps if you posted a model just so we are working on the same problem.
        http://sdmitch.blogspot.com/
        • N Offline
          niccah
          Oh, that's so nice! Thanks a lot for your help!
          I uploaded a Sketchupfile:
          http://arbeitenkannstduspaeter.eu/Sketchup/Test3.skp
          When you get the right result - this means, I have to look for the problem on an other position... puhh...
          • N Offline
            niccah
            Okay, I played a little bit with this problem...
            My new findings:
            • when I move the group, the transformation of the outer group change in the right way
            • but I have still an offset (in my case in -x direction)
            Perhaps it helps a little bit to find the main problem!? ๐Ÿ˜„
            • N Offline
              niccah
              I think, I solved the problem - but I don't know exactly, what WAS wrong...
              I saw, by copiing the selected faces into a new group, not every face has the original direction. So, I changed my Face.copy function (I know, its not good to change the Face.class, but I will solve THIS problem later) in that way:
              outer_face = ents.add_face ov outer_face.material = "green" if outer_face.normal != self.normal outer_face.reverse! end
              Now, all the faces have the right direction and now the problem with the offset of the points is gone.
              But, to be honest, I have realy no idea, how these two problems correlate! And it doesn't help, to change the direction of these faces by hand - the problem stays! Just by copiing all the faces again, the problem of the offset is gone!
              Do you have ANY idea what's going on?
              I thank you sohhhhh much for all your support!!! You helped my realy a lot!
              • 2 / 2
