    EntitiesObserver and attributes
    7 Posts 2 Posters 456 Views 2 Watching
    • R
      rvs1977
      Im working with EntitiesObserver, and having trouble understanding the method
      def onElementModified(entities, entity).
      For instance, if you add an EntitiesObserver to a group consisting of a face, the EntitiesObserver will fire when you doubleclick the group and alter the face.
      (Eg. moving one of the edges so that the area of the face will increase.) In that case it will fire 3 times because 2 edges will get longer, and the face itself will increase in size.
      If you have set an attribute to the face it is then possible to retrieve the value by saying
      myFaceAttr = entity.get_attribute "rsdict", "face_attr", and you can set a new value with set_attribute "rsdict", "face_attr", "new value".
      But now my question is: what if I have an attribute set to the group, and I want to alter that when the EntitiesObserver fires. Is it possible to see name of the parent of the entity? (The face is a child of the group)
      Hope the question is understandable... πŸ˜’
      -Rasmus
      Get a Ruby
      • Dan RathbunD
        Dan Rathbun
        model#active_path
        Get the group instance's name from inside the observer callback:
        editpath = entities.model.active_path
        grp =( editpath.size > 0 ? editpath.last ; nil )
        name =( grp ? grp.name ; "" )
        Get the group definition's name from inside the observer callback:
        entities.parent.name
        A Group is a special flavour ComponentInstance, so it therefor has a ComponentDefinition, which is the real owner of the Entities collection.
        πŸ’­
        I'm not here much anymore.
        • R
          rvs1977
          Thank you Dan, but I try to explain it again:
          My goal is to set an attribute to the group when a face has been modified. As you can see in the code below Im able to set an attribute to the face inside the group, but not the group containing the face. Do you have any ideas how to work around this problem?
          If the group is called rsgroup:
          yv_face_height = rsgroup.entities.add_face pts[0..3]
          rsgroup.set_attribute "rsdict","area", yv_area
          yv_face_height.set_attribute "rsdict", "yv_face_area", yv_area
          class MyEntitiesObserver < Sketchup;;EntitiesObserver
                  attr_area = entity.get_attribute "rsdict", "yv_face_area"
                          if attr_area
                              yv_area_new = i.area.to_m.to_m
                              entity.set_attribute "rsdict", "yv_face_area", yv_area_new
                              #(HERE I WOULD LIKE TO SET THE ATTRIBUTE OF THE GROUP-something like;)
                              entity.parent.set_attribute "rsdict","area", yv_area_new
                          end #attr_area
              end #onElementModified_end
          end #class
          Get a Ruby
          • Dan RathbunD
            Dan Rathbun
            I showed you how to get a reference to the group (named grp in my example, above.)
            Just ignore the calls to get the name ... BUT ...
            ... you have a vicious circle situation.
            Changing attributes fires observers on Entities collections.
            In SketchUp:
            I made a box and grouped it. And left it selected.
            I made a ref to the group:
            grp = Sketchup.active_model.selection[0]
            At the Ruby Console, I defined a quick checker class:
            class Spy; attr_accessor(;name); def initialize(spy); @name = spy.to_s; end; alias_method(;has_method?,;respond_to?); # override respond_to? method; def respond_to?(meth); puts("\nSpy '#{self.name}' method '#{meth.to_s}' was called by Sketchup."); has_method?(meth); end; end
            Then made two spy instances:
            mspy = Spy.new("Model Entities Spy") gspy = Spy.new("Group Entities Spy")
            And attached them:
            Sketchup.active_model.entities.add_observer(mspy) grp.entities.add_observer(gspy)
            Then added a dummy attribute:
            grp.set_attribute "rsdict","area", (1.23).to_l.to_m.to_m
            This was the output to the console:
            [pre:gsyu95n9]Spy 'Model Entities Spy' method 'onElementAdded' was called by Sketchup.
            Spy 'Model Entities Spy' method 'onElementRemoved' was called by Sketchup.
            Spy 'Model Entities Spy' method 'onElementModified' was called by Sketchup.
            Spy 'Group Entities Spy' method 'onElementAdded' was called by Sketchup.
            Spy 'Group Entities Spy' method 'onElementRemoved' was called by Sketchup.
            Spy 'Group Entities Spy' method 'onElementModified' was called by Sketchup.[/pre:gsyu95n9]
            Problem is you are already within the EntitiesObserver instance attached to the Group's Entities collection !
            You must be careful not to set up an infinite loop !
            Changing the model from within observer callbacks can crash SketchUp !
            • R
              rvs1977
              Ok, for now I will abandon this approach.
              Please consider this example:
              mod = Sketchup.active_model
              ent = mod.entities
                    i = 0
              		h= {}
              		ent.each do |o|
              		attr = o.get_attribute "rsdict","area"
              			if attr
              			   h[i] = {'structid' => 201, 'area' => attr}
              			   i += 1;
              Here it scans the entire model for groups with the attribute_dictionary "rsdict", "area".
              Lets say it finds a group with the "rsdict" attribute. Inside the group there are a face
              with an attribute attached to it.
              Is it possible to scan that group for all its entities? Something like this:
              ent = mod.entities
                    i = 0
              		h= {}
              		ent.each do |o|
              			if attr
                                         o.entites.each do |u|
                                         yv_face_area = u.get_attribute "rsdict", "yv_face_area"
                                         if yv_face_area
                                             h[i] = {'structid' => 201, 'area' => yv_face_area}			                       i += 1;
              Get a Ruby
              • Dan RathbunD
                Dan Rathbun
                Something more like:
                ent = mod.entities
                h = {}
                ent.each_with_index do |o,i|
                  next unless o.is_a?(Sketchup;;Group)
                  attr = o.get_attribute("rsdict","area")
                  if attr
                    o.entities.each do |u|
                      next unless o.is_a?(Sketchup;;Face)
                      yv_face_area = u.get_attribute("rsdict", "yv_face_area")
                      if yv_face_area
                I wonder why you are using ordinal integers as hash keys ??
                You might as well just use an array:
                ent = mod.entities
                h = []
                ent.each do |o|
                  if attr
                      if yv_face_area
                        h << {'structid' => 201, 'area' => yv_face_area}
                • R
                  rvs1977
                  Great, this solved my problem! Thank you very much Dan! πŸ˜„
                  Get a Ruby
