    Kerkythea animation frames and master model
    Scheduled Pinned Locked Moved Post Processing
    3 Posts 2 Posters 8.3k Views 2 Watching
      medicanic7
      Hello forum.
      I am attempting to create animation frames in Kerkythea.
      The animation frames (.jpeg) do not show the sky global that was inserted into the master model (.xml). I run the script for the animation, and I notice the jpeg's being created are missing the sky global. How can this problem be corrected?
      Attached, are the animation files (.xml & .jpeg), master model (.xml), and animation script (.kst). See the zipped file which includes all of these files.
      Thank you for your assistance.
      This zipped file contains all the files mentioned in this topic post
      • majidM Offline
        majid
        adding global doesn't must be done over your background setting,...
        making an animation is done using adding cameras , then tools-->Walktrough animation
        dav.zip
          medicanic7
          Thank you majid.
          I can see the animation walk through named dav. Now, I am trying to determine how to play the animation.
