Using Netbeans as IDE for SketchUp
At Basecamp the people of 3skeng showed a way to connect netbeans to sketchup for using it as full working IDE for SU.Does somebody knows how to do it?
Hi Guy,
3skeng could have their own internal solution, you would need to ask them.
There is a possible way using TBD's "bridge" plugin. You would need to configure netbeans to execute the buffer using the sub.exe file in bridge. This is a Windows plugin and I see your profile says Mac so you may be out of luck.
Register LoginAdvertisement
