    Custom selection tool
    7 Posts 3 Posters 496 Views 3 Watching
    • A
      ArunYoganandan
      Hi All,
      As some of you might be familiar, I'm building an immersive version of Sketchup. One of the custom tools I'm building is a 3D selection tool. i.e, you select objects that lie within a cuboid in 3D rather than a rectangle drawn in screen space.
      The selection algorithm basically walks through all the entities in the active_model.entities and checks to see if the bounds of the entity are intersecting/contained with that of the selection cube or not.
      One of the difficulties I'm facing is with curved surfaces like a cylinder. My algorithm seems to be selecting every edge on curved surfaces, rather than the just the surface.
      https://lh3.googleusercontent.com/-uce63AbM914/UIBN8hiEX-I/AAAAAAAAkUU/NcLMsdKbmzY/s1440/Screen%2520Captures1.jpg
      Here is a screenshot. To the left is the effect of using Sketchup's native selection tool and to the right is the one I wrote. SU's native tool selects 72 entities, while mine selects 96. On comparing the entities, the extra ones I have are edges on the curved surface.
      I have two questions.
      a) Is there a way to differentiate these edges on curved surfaces from others, so I don't include them in selection.
      b) My performance is really slow with curved surfaces. Does SU have a region selection mechanism? or is there a better algorithm I can use than what I described above. I can post code snippets if needed.
      Thanks in advance for your help
      Arun
      • sdmitchS
        sdmitch
        As for question 1,the "dashed" lines defining the edges of the faces that make up the surface should be excludable by testing edge.soft? and edge.smooth? and ignoring it if either is true.
        As for question 2, the only thing in the SU API related to this is the Geom.point_in_polygon_2D which is useless in this case. If you would care to post the code you are currently using, maybe I or someone could offer an openion on what might be done to speed things up.
        http://sdmitch.blogspot.com/
        • Dan RathbunD
          Dan Rathbun
          One thing is you should be iterating the active_model.active_entities collection, to be sure and only select items in the current editing context. (Which could be the entire model.)
          I'm not here much anymore.
          • A
            ArunYoganandan
            edge.soft? and edge.smooth? did get rid of the dashed lines. Thanks so much!
            Here is the function I'm using
            		def selectInVolume( view)
            		#Add the corners from the 3D selection box into a selection volume
            		selectionVolumeBBox = Geom;;BoundingBox.new
            		selectionVolumeBBox.add @corner1
            		selectionVolumeBBox.add @corner2
            		selectionVolumeBBox.add @corner3
            		selectionVolumeBBox.add @corner4
            		selectionVolumeBBox.add @corner5
            		selectionVolumeBBox.add @corner6
            		selectionVolumeBBox.add @corner7
            		selectionVolumeBBox.add @corner8
            		sel = Sketchup.active_model.selection
            		universalList = Sketchup.active_model.entities
            		universalList = universalList.to_a - $unSelectableList
            		universalList.each{ |b|
            			if(b.class != NilClass )
            				if(b.visible? == true)
            					allCornersLieWithin = true
            					boundBoxObject2D = b.bounds
            					resultantboundBox =  boundBoxObject2D.intersect selectionVolumeBBox
            					status = resultantboundBox.empty?
            					if(status)
            					else
            						if(selectionVolumeBBox.contains?(b.bounds.center))
            							for i in 0..(7)
            								pt = (b.bounds.corner(i))
            								if(!selectionVolumeBBox.contains?(pt))
            									allCornersLieWithin = false
            									break
            							if(allCornersLieWithin == true)
            									sel.add b
            						else
            							#if center doesnt lie within, then no point in checking for corners. the object clearly is not completely within
            • A
              ArunYoganandan
              Thanks for the suggestion. I revised my code to active_entities. Doesn't seem to make much of a difference in performance right now, but I see your point as to how it could in other situations.
              • sdmitchS
                sdmitch
                Using the BoundingBox certainly works as long as the selection box is not rotated which will cause BoundingBox to be much larger than the selection box.
                I see no reason why the selection process should be any slower on a curved surface. It should only matter how many total entities there are in the model.
                • A
                  ArunYoganandan
                  Yea. That is the same thing I'm confused about as well. Unless SU has a way of selecting the cylindrical surface as one unit or a collection rather than add each face of the curved surface one after the other(which is what my code does). Also, all my conditionals could be slowing things down as well.
                  The selection box is axis aligned, so the they bounding box and the selection box should pretty much be the same size.
