    [Help] Create "Check for Update" event
    2 Posts 2 Posters 141 Views 2 Watching
      Anton_S
      So far, I've kind-of mastered new scripting knowledge, and plugin rules. 😎 Although, now I want to create a Check for Update event to certain plugin. /Me wants to learn πŸ˜•
      • Lets say I have a certain storage, such as google drive, bitbucket, or 4shared, which holds my plugins.
      • Client downloads the plug, afterwards launches SU, and selects [Plugins/"my plug"/check for update] menu item event.
      • I would like the plugin to compare version (or release date) between the current user plugin and the one on certain storage.
        Pending, give results
      • If finds an update, the plugin must show a message "New update... Want to download?... [yes],[no]"
      • If yes, I want the original plugin to be deleted, and the new one downloaded to original plugin path - automatic process
      The question is how to compare versions, and how to replace the plugin with automatic process.
      Indeed, inspired with replies, suggestions... πŸ˜„
      • Dan RathbunD Offline
        Dan Rathbun
        Everyone wants this functionality.
        Some work has been done.
        ExtendSketchUp has this goal.
        Fredo6 created a web-based update checking feature. (Do a search.)
        Others have done it with a UI::WebDialog
        You will likely need to use the functionality in the SketchupExtension class for installed versioning.
        Unfortunately.. the community has not yet agreed upon a file manifest format to track installed file locations. (So an uninstaller can remove them.)
        I'm not here much anymore.
