    Sharing variables between functions
    3 Posts 2 Posters 290 Views 2 Watching
    • K Offline
      kybasche
      Hey all.
      One day, I'll get good enough at this to offer help instead of only asking question.
      But for now:
      I would like to be able to use variables from one function inside a different function. Please forgive my poor scripting - but as an example...
      module Plugin
      unless file_loaded?("program.rb")
      mymenu = UI.menu('Plugins').add_submenu('test')
      mymenu.add_item('Test Program') {self.Box}
      mymenu.add_item('Test Program 2') {self.Circle}
      file_loaded("program.rb")
      end #unless
      def self.Box()
      a = 5
      b = 6
      c = a * b
      end #Box
      def self.Circle()
      d = 12
      e = d * a ##this won't work of course, because (a) is not defined within this function... how do you pull the value of (a) from Box?
      end #failCircle
      end #module
      Thanks much!
      Derek
      • ChiefwoodworkerC Offline
        Chiefwoodworker
        Hi Derek,
        Make variable a a class instance variable e.g.@a.
        def self.Box()
        @a = 5
        b = 6
        c = @a * b
        end #Box
        def self.Circle()
        d = 12
        e = d * @a
        end #module
        Joe....
        http://www.srww.com
        • K Offline
          kybasche
          amazing how easy things are sometimes.
          guess i have a long way to go πŸ˜„
          thanks!
          D
