Interactive 360 Panoramas - My latest two.
Hey there! I'm here to share with you my latest two Interactive Panoramas. Here are the 2 images used to generate the Interactive final product. I used SketchUp, Vray for Sketchup and Photoshop to generate these images.
Since I cant embed te flash (.swf) final files here I'll leave you to the links on my blog that had the final panoramas embeded.
Coments and critics are always welcome. See you soon!COUPLE'S ROOM: (Widescreen proportion 16:9)
Link to the Final Interactive Panorama
http://www.arqmaniaco.blogspot.com.br/2012/07/panoramica-360-quarto-casal-por-atb.html
SINGLES MAN'S ROOM: (Normal proportion 4:3)
http://www.arqmaniaco.blogspot.com.br/2012/07/panoramica-360-quarto-solteiro-por-atb.html
Nice panoramas!
I would suggest that you ensure that the vertical lines are vertical in the equirectangular images so that the horizon has no waves during the rotation of the panorama.Like this...
@cotty said:
Nice panoramas!
[attachment=0:2w0c2npk]<!-- ia0 -->atb_vertical.jpg<!-- ia0 -->[/attachment:2w0c2npk]I noticed that error and the weird results on the first panorama. I just wasn't sure how would I fix that on PS or even better, I couldn't figure out why the the straight image from Vray was generated like that. Can you give me any advices on what Tool to use on Photoshop to fix that like you just did?
Thanks in advance and thanks for commenting!
I don't know Vray, so I'm not able to say anything about the reason.
But I am using the software hugin to stitch my panorama photos, maybe you can use your Vray-output with it? -
But I am using the software hugin to stitch my panorama photos, maybe you can use your Vray-output with it?Hey again!
What I meant is that I am curious to know how you straighten the wall corner lines on my already rendered image. You probably fixed it on Photoshop, right? How did you do it? -
No, I did use the move/drag function from hugin for the correction. I don't use Photoshop for this.
