    Identify/locate the Subclass
    4 Posts 2 Posters 266 Views 2 Watching
    • A
      Anton_S
      During coding I came up to the point where I needed to figure whether the selected object is a sublcass of a class. I mean like Sketchup.active_model.select_tool only accepts subclasses, right? And it only works if the tool includes some of its methods, such as onMouseMove.
      I can predict how it works. Maybe it uses @selected_tool.include?(certain_method), If method not inclduded, then the tool jst ignores the callback to current message. But with this assumption the ...select_tool method will also accept anything, but not nil, as it describes in the API description.
      Is there a way to actually know whether the selected tool is actually a subclass of a class?
      • Dan RathbunD
        Dan Rathbun
        Specifically.. about SketchUp API Tool classes:
        There is NO defined Tool superclass.
        That means that your custom tool class definition will be a subclass of Object.
        Now, because of that.. Sketchup.active_model.select_tool() does NOT do any typechecking, other than to check if a nil argument was passed.
        So.. when you pass an object to Sketchup.active_model.select_tool() (and it's not nil,) SketchUp expects it to have the minimum of the Tool class callbacks. (I think activate would be the minimum.)
        To ask an object if it has a public activate method:
        obj.respond_to?(:activate)
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          About classes in general:
          The logical methods can apply at the class level.
          For instance, class Class, is a subclass of class Module.
          so: Class < Module returns true
          and: Class > Module returns false
          further, Object is THE supreme class, the common progenitor of all other classes.
          so: Class > Object returns false
          and Object is always greater than any other class.
          So IF you decide to set up your own tool protoclass... Anton::Tool
          and you wanted to see if a specific tool instance was a subclass:
          nifty_tool.is_a?(Anton::Tool)
          or
          nifty_tool.class < Anton::Tool
          ... would return true, if nifty_tool's class was a descendant class of Anton::Tool.
          If you wanted to see a list of nifty_tool's ancestors:
          puts nifty_tool.class.ancestors
          πŸ’­
          • A
            Anton_S
            Thanks Dan, description - sure will help.
            Edited: Previously, I used obj.methods.include?(someMethod). - That will give an error if the object wouldn't be a class, nor module. But using respond_to? will work on any selected object without errors. Jst true or false
            I was wrong in blue words. Actually, .methods can be implemented in any object. 134.methods, nil.methods, "dsfg".methods, false.methods, Class.methods will always work.
