    Animation resolution - export from SketchyPhysics
    2 Posts 2 Posters 1.3k Views 2 Watching
    • P Offline
      pawelwozny
      Hi everyone!
      This is my first post on this board. Does anybody know how to change image resolution in SketchyPhysics export option? Normally it has the resolution of view in Sketchup (for me 1300x606 px), but what I need is much more bigger (better quality).
        DanYHKim
        Don't know how to help you directly, but you might consider using a different codec. Some codecs will be more lossy in their compression than others.
        There is a freeware screen capture program called CamStudio that has a lossless codec available for download. Once installed, you may be able to choose the lossless codec for your video export, giving you a file that is gigantic in size and hard to work with, but which may then be transcoded successfully to another format with better results.
        I am guessing, but it's worth a shot.
