    Given a x,y,z location to move a selected group help! solved
    4 Posts 2 Posters 373 Views 2 Watching
    • dukejazzD Offline
      dukejazz
      Is there a way in ruby code, given a x,y,z location to move a selected group directly to that location?
      Need help for my scale upgrade, best I can do is a iteration.
      • sdmitchS Offline
        sdmitch
        mod = Sketchup.active_model
        ent = mod.entities
        sel = mod.selection
        if sel.first.class==Sketchup;;Group || sel.first.class==Sketchup;;ComponentInstance
         inp=inputbox(["X;","Y;","Z;"],[0,0,0],"Move Component/Group to")
         if inp
          x,y,z=inp;move_to=Geom;;Point3d.new(x.to_f,y.to_f,z.to_f)
          move_from=sel.first.transformation.origin;
          tr=Geom;;Transformation.translation(move_from.vector_to(move_to))
          sel.first.transform! tr
        http://sdmitch.blogspot.com/
        • dukejazzD Offline
          dukejazz
          Thank you.
          I will give it a try πŸ˜„
          • dukejazzD Offline
            dukejazz
            Thank you, Sdmitch for your help
            History
            v1.1 May 27
            -fix move iteration problems
            scaleGroupFloat_dj Ver 1.1
            Copyright 2012, May 27
            DukeJazz: James Cochran
            http://forums.sketchucation.com/viewtopic.php?f=323&t=45254&p=404860#p404860
            My final form
            #sents
            ss =Sketchup.active_model.selection
            if ss.empty? then
            UI.messagebox ("Please Select. a goup.");return
            sents = [];ss.each{|e|sents.push(e)}
            #_API____Geom::move! new_transformation
            entity_group=Sketchup.active_model.active_entities.add_group(sents)
            Geom::Transformation.new [x1,y1,z1]
            entity_group.move!(Geom::Transformation.new [x2,y2,z2])
            entity_group.explode
