    Retrive the tool selected before launching my plugin
    12 Posts 3 Posters 1.1k Views 3 Watching
    • N
      njeremy2
      Hello everyone ! β˜€ (35Β°C in South of France)
      Today I have a new enigma, I need to create a plugin which allow us to choose 3 points and find the center of the them.
      This part is done but for this plugin I need more.
      My plugin should work like that :
      1. I select the tool (circle tool for example), a component or something else...
      2. I launch the plugin
      3. I select my 3 points
      4. The center is draw and the circle tool is activate on the center (or component placed here).
      example :
      http://img39.imageshack.us/img39/275/79886999.jpg
      I search on Google Sketchup API and automatic sketchup PDF, I use Sketchup.send_action "selectCircleTool:" for activate the plugin circle tool.
      I should retrive the tool before lauching the plugin, I try this :
      tools = Sketchup.active_model.tools
      Sketchup.send_action "#{tools}"
      or
      tools = Sketchup.active_model.select_tool nil
      I succeed how to pick a component to put in the center but I don't know how to retrieve a tool selected before
      Someone can help me ? πŸ˜„
      • Dan RathbunD
        Dan Rathbun
        current_tool_id = tools.active_tool_id
        # may be 0 if no active tool, so watch out!
        # this might happen just after SketchUp starts
        # you can get active tool name IF, and only IF
        # active_tool_id != 0. If it is 0 and you call
        # active_tool_name, you cause a BugSplat! crash.
        current_tool_name =( tools.active_tool_id != 0 ? tools.active_tool_name ; "SelectionTool" )
        Then set your custom tool as the current tool,
        when done you can use the previous id or name
        to call Sketchup.send_action but
        you have to have a action string hash, because
        some of then differ from the names returned by
        the Tools.active_tool_name method.
        See these posts for a lookup hash examples:
        http://forums.sketchucation.com/viewtopic.php?t=18124
        In this one (below) you'd have to cut & paste the hash into your OWN namespace:
        (Do not distibute it so that it modifys the Sketchup::Tools class. It's an example for Google/Trimble only, of how the API class might be modified in the future.)
        http://forums.sketchucation.com/viewtopic.php?f=315&t=36177
        Also be aware that if the previous tool was a custom tool, then the Tools.active_tool_name method ALWAYS returns the string "RubyTool".
        IF this happens you can call the previous tool on Windows by passing the tool id as an integer argument (not a string,) to Sketchup.send_action(), but not on Mac/OSX.
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          You can also use a Tools observer subclass:
          https://developers.google.com/sketchup/docs/ourdoc/toolsobserver
          • K
            kwalkerman
            I think what you want to do is re-select the tool the user originally had selected when they activated your plugin. To do it:
            original_tool = Sketchup.active_model.tools.pop_tool
            myTool.activate
            # Now execute your code.  When you're finished, maybe in the tool's deactivate method;
            Sketchup.active_model.tools.push original_tool
            Karen
            • Dan RathbunD
              Dan Rathbun
              Karen that will not work (presently) as the pop_tool() method is bugged. It returns boolean, not the tool object. (I think I entered an API bug for this.) It can also set up the situation where the tool stack is empty if there was only 1 tool in it, and the active_tool_id is 0 until some valid tool is selected.
              In addition the push_tool() method only accepts a UI::Tool class object (or the API dictionary says that is what it expects. But since there really is no UI::Tool protoclass, does the method do any typechecking at all?)
              Apparently not as:
              Sketchup.active_model.tools.push_tool 21013
              Does not select the Component Placement tool, but it returns true anyway.
              • N
                njeremy2
                I'm gonna test it right now πŸ˜„
                • N
                  njeremy2
                  Hmmmmmmm
                  I a little bit hard to use ...
                  To begin easily, I made a plugin which display the name of selected tool
                  I will show you the progress πŸ˜‰
                  • N
                    njeremy2
                    Hmmm, it's little bit weird :
                    When I retrive the ID of the tool with your solution, I obtain an ID number but when I launch a second time the plugin, I have a second ID number. WHY ??? πŸ˜’
                    But, I've try this:
                    @model = Sketchup.active_model
                    @tools = @model.tools
                    @name = @tools.active_tool_name
                    @name2 = "select#{@name};"
                    Sketchup.send_action "#{@name2}"
                    It works for most of tools except for LineTool (it's called "SketchTool" instead of "Linetool"), polygon, axis tool.
                    Maybe if I can retrive the ID with "@id = @tools.active_tool_id" and "Sketchup.send_action (@id)" it should be better but how do we do ?
                    • Dan RathbunD
                      Dan Rathbun
                      @njeremy2 said:
                      Maybe if I can retrive the ID with @id = @tools.active_tool_id and Sketchup.send_action (@id) it should be better but how do we do ?
                      1) Yes you CAN use id, but ONLY on PC/Windows.
                      It does NOT (currently) work for Mac/OSX.
                      2) NEVER put a space between the method name and the ( of it's argument list.
                      • Dan RathbunD
                        Dan Rathbun
                        We know. This is why I told you (in post http://forums.sketchucation.com/posting.php?mode=quote&f=180&p=405232#pr404805 ) that you need a send action lookup hash.
                        • N
                          njeremy2
                          ahhh ok !! lol sorry !
                          You write too much text and google translation doesn't translate very well ! πŸ˜„
                          • N
                            njeremy2
                            Now, I'm using name to identify the tool
                            For this moment it works πŸ‘
                            I don't understand the ID method, maybe when I feel ill at ease with ruby, I can understand how it works
                            Thank you Dan and Karen !!
