    [REQ] Edge 2 Groove
    68 Posts 11 Posters 7.7k Views 11 Watching
    • EarthMoverE Offline
      EarthMover
      I certainly will Sam. I have a bunch of billable work to finish up with at them moment, but will get you some test models as soon as I'm done. Unless someone else has time.
      C'mon people.....get your grooooove on! 😄
      Content Creator at Skapeup
      • mitcorbM Offline
        mitcorb
        @sdmitch:
        Regarding the column and up/down question, could you relate the action to a centroidal axis about which the grooving happens? Just throwing out ideas. It might work for any linear form. Define the line, series of segments, curve as the axis, precursor to the process?
        Vaguely related to Lines2Tubes or Tube Along Path.
        • sdmitchS Offline
          sdmitch
          mit, That is a certainly a possibility and using followme instead of pushpull. The problem will always be sorting out which edges should be followed unless the paths are selected one at a time.
          http://sdmitch.blogspot.com/
          • pbacotP Offline
            uploading a cabinet example. Grooves are very small. Thanks! P
            (I for one have NO billable time today 😞 )
            cabinet with grooves.skp
            • mitcorbM Offline
              mitcorb
              Hi, sdmitch:
              I didn't necessarily mean you would use a followme function. More like the centroidal path being continuous through the core of the linear construction, but used as a reference axis at the interfaces of the units from which a groove offset is determined for each brick, tile, stone, whatever, and then some kind of process that shrinks the offset. Alternatively a Dynamic Component is developed with abilities to skew faces, tegularize, or rebate edges?
                EarthMover
                Hey Sam, here are a bunch of different groove scenarios, which all fail with the current plugin, some causing crashes. Thanks again.
                Groove Maker Scenerios.skp
                • sdmitchS Offline
                  sdmitch
                  I'm not surprised that the plugin fails and/or splats on these examples. It is going to be very tough if not impossible to come up with a general solution.
                    EarthMover
                    I suspected as much. A general solution would spend more time inspecting than processing I suppose. Grooves on a single (non-extruded) face should be quite simple, but I imagine the code would vary from solving the edges that turn corners. Edges that support co-planar faces and turn corners is a different procedure than those that turn corners and support non-planar. Also edges that form a "C" as opposed to closed loop would be processed different as well. Could there possibly be a prompt to help the script identify the situation before the process runs? It appears there is an overwhelming desire and need for the (universal) script, across many different industries, but I certainly understand the nature of edges in sketchup and the inability to identify them as they have no "normals" like faces do. I'm however, still hopeful for a solution.
                    • 4 / 4
