    Ruby Module Variables
    10 Posts 3 Posters 2.8k Views 3 Watching
    • A
      Anton_S
      Based on the reference: Module Variables, I figured that it's valid to create instance variables inside the Module. I tested it on SU via Ruby and it all worked, without any conserns. Though, some of Ruby things began bugging me, and thus I need a good confirmination.
      1st: Creating instance variables in module namespace is valid, though is it right and why?
      2nd: Since, you can't create an instance of a module (SomeModule.new = No function such as new) then, why are there things such as module instance methods (def someMethod) and module class methods (def self.someMethod)?
      3rd: Getting even deeper, I figured that it is valid to create constants inside the class. They act the same way as class variables, though as usual ruby would warn once the constant is assigned a different value. So, is it also right to initiate constants inside the class namespace?
      4th: What is a difference bettween instance variables and class variables in the module?
      • Dan RathbunD
        Dan Rathbun
        @anton_s said:
        2nd: Since, you can't create an instance of a module (SomeModule.new = No function such as new)...
        WRONG
        class Module, like ALL Ruby objects, has a new() constructor class method (which is a block form method,) ie:
        Anton = Module.new() {
          @color = blue
          def self.get_color()
            @color
        Remember that a Ruby script is for humans to read.. Ruby does not really use it. The interpreter reads the script " module Anton" and translates it into a constructor call (similar to the above example,) but in C code.
        @anton_s said:
        ... then, why are there things such as module instance methods (def someMethod) and module class methods (def self.someMethod)?
        Because modules can be the library type (best used with module/class variables and module/class methods,) OR the "Mixin" type, which are used to mixin instance variables and instance methods into custom classes. (You can also create a hybrid that is both types, like the Math module is.)
        So.. read up on Mixin Modules.
        I'm not here much anymore.
        • J
          Jim
          Great questions, Anton.
          Around here modules are used mainly as namespaces to wrap methods and avoid method name conflicts. More typically in ruby, modules are used to implement the object-oriented programming concept called multiple inheritance (called mixins in Ruby.)
          As far as I know, a instance variable, a class variable, and a constant will all have the same visibility (scope) when defined at the top-level of a module. They will all be visible everywhere within the module namespace, including classes and other modules defined within the module. A unique feature of Ruby is that these same objects (classes, modules, variables) are visible across files if the files use the same names.
          Which is "right" may come down to convention and personal preference.
          • Dan RathbunD
            Dan Rathbun
            YES you may. But do not use Constants in place of variables. (At some time in the future the Core guys are not going to let us change them.)
            To prevent the warning (say during debugging... wrap Constant definitions within a "Run Once" conditional.
            unless file_loaded?(__FILE__)
              DELIMITER = ","
              RECORD_END = "\n"
            or:
            DELIMITER = "," unless defined?(DELIMITER)
            or
            DELIMITER ||= ","
            If you really must change a Constant, you can use the remove_constant(:CONSTANTNAME) private method within your namespace first, then redefine it.. and there will be no warning output.
            • Dan RathbunD
              Dan Rathbun
              What Jim says is true.. personal preference.. but I will usually advise using module variables for library modules and namespaces, and save instance variables for mixin modules and classes.
              But Ruby is designed to be multi-paradigm, so you can do things in the way you feel most comfortable.
              In modules, it's subtle.
              If you use a proxy class block within your module (which makes things A WHOLE LOT EASIER...) then Constants and module variables need to be defined outside the proxy class block, but instance variables need to be defined within it:
              require('sketchup.rb')
              module Anton;;FancyPlugin
                unless file_loaded?(File.basename(__FILE__))
                  # Constants
                  Border = "blue"
                  # Module Vars
                  @@opts = {}
                class << self # PROXY CLASS
                  # INSTANCE VARS
                  @counter = 0
                  @limit = 100
                  @@opts[;limit]= @limit
                  def set_limit(arg=100)
                    if arg.is_a?(Numeric)
                      @limit = arg.to_i
                      @@opts[;limit]=@limit
                end # PROXY CLASS
                # We can call methods in the proxy class
                # from inside module without qualification;
                set_limit(99)
                file_loaded(File.basename(__FILE__))
              end # module Anton;;FancyPlugin
              # from outside the module WITH qualification;
              Anton;;FancyPlugin.set_limit(125)
              • A
                Anton_S
                Thanks, for a great replie(s) Dan and Jim
                Well, isn't this:
                >   @color = 'blue'
                >     @color
                >   end
                the same as this:?
                module Anton
                  @color = 'blue'
                    @color
                I don't see any difference in these
                Found a really good explanation here, thanks πŸ˜„
                • A
                  Anton_S
                  Alright, so are the two namespaces below right and which of them do you prefer better:?
                  module CandiesM
                    @@count ||= 0
                    def self.buy(); @@count += 1; end
                  class CandiesC
                    @@count ||= 0
                  • Dan RathbunD
                    Dan Rathbun
                    No kidding! That was exactly the point I was making.
                    • Dan RathbunD
                      Dan Rathbun
                      This:
                      module Anton
                        module CandiesM
                          @@count ||= 0
                        class CandiesC
                          @@count ||= 0
                      end # module Anton
                      All of your modules and/or classes need to be within your "author" namespace.
                      If you need one copy of some code, make it a module.
                      If you need multiple copies of some code, make it a class, and use multiple instances of the code.
                      • A
                        Anton_S
                        Ok, good advice, thaks πŸ˜„ . Now I'm on my way to 'Keep on typing' the code.
