    [Code] intersect_with?() Group test method
    2 Posts 2 Posters 1.3k Views 2 Watching
    • Dan RathbunD
      Dan Rathbun
      *Author*::*SomeLib*.intersect_with?( grp1, grp2 [, precision] )
      Test whether two groups have a boolean intersection. Returns true || false.
      ( Method is non-destructive, and does not change either reference. )
      module Author;;SomeLib
        class << self # PROXY CLASS
          #{ intersect_with?( grp1, grp2 [, precision] )
          #  Test whether two groups have a boolean intersection.
          #  (Method is non-destructive, and does not change either reference.)
          #  grp1  ; a Sketchup;;Group or Sketchup;;ComponentInstance reference.
          #  grp2  ; a Sketchup;;Group or Sketchup;;ComponentInstance reference.
          #  precision ; number of decimal places for precision (default = 3.)
          #  Returns; true,  if "grp1" intersects with "grp2" argument.
          #           false, if they do not intersect.
          #           nil,   if either are not manifold, Sketchup is not Pro,
          #                    or if the groups are in different contexts.
          def intersect_with?( grp1, grp2, prec=3 )
            unless grp1.is_a?(Sketchup;;Group) || grp1.is_a?(Sketchup;;ComponentInstance)
              raise(TypeError,"(arg 0) Sketchup;;Group or Sketchup;;ComponentInstance expected.",caller)
            unless grp2.is_a?(Sketchup;;Group) || grp2.is_a?(Sketchup;;ComponentInstance)
              raise(TypeError,"(arg 1) Sketchup;;Group or Sketchup;;ComponentInstance expected.",caller)
            return nil unless Sketchup.is_pro? && Sketchup.version.to_i>7
            return nil unless (grp1.manifold? && grp2.manifold?)
            return nil unless (grp1.model == grp2.model)
            return nil unless (grp1.parent == grp2.parent)
            tgrp = nil
            retval = false
            mdl = grp1.model
            vola = volb = grp1.volume.to_l
            begin
              mdl.start_operation('Intersect Test')
              if grp1.is_a?(Sketchup;;Group)
                tgrp = grp1.copy
              else grp1.is_a?(Sketchup;;ComponentInstance)
                tgrp = grp1.parent.entities.add_instance(grp1.definition,grp1.transformation)
              vola = grp2.trim(tgrp).volume.to_l
              mdl.commit_operation
            rescue Exception => e
              mdl.abort_operation
              puts(e.message)
              puts(e.backtrace)
              return nil
            else
              Sketchup.undo
              if prec==3
                return puts( vola == volb ? false ; true )
              else
                aft = ((vola*(10**prec)).to_i)/((10**prec).to_f)
                bef = ((volb*(10**prec)).to_i)/((10**prec).to_f)
                return puts( aft == bef ? false ; true )
          end #}
        end # PROXY CLASS
      end # module
      Tested OK with 2 cuboids that intersected at their corners by 0.001" x 0.001" x 0.001"
      πŸ’­
      I'm not here much anymore.
      • B
        buidoi3003
        May I know after determining if the 2 groups/ components/ faces are intersected. How do I get the area of the intersection?
