    [Question]how to load a tool from an external .rb file
    4 Posts 2 Posters 217 Views 2 Watching
      rvs1977
      Hi All πŸ˜„
      Once I made a simple linedrawing tool, capable of drawing straigt lines.
      Its saved in a file called mylinetool.rb in \Plugins\as_plugins\as_rubyeditor\snippets
      The question is, how do I make a small rubyscript that loads and runs the tool from Alex Schreyers Ruby Code Editor?
      Is it something like "load_file", "include" or "load(filename)"??
      Can it be loaded from a URL? eg. http://www.google.com/mylinetool.rb
      thanks in advance
      -Rasmus
      Get a Ruby
      • Dan RathbunD Offline
        Dan Rathbun
        If it is a plugin.. it is no longer a "snippet" ...
        Move it into YOUR author sub-directory of the "Plugins" directory.
        So.. example, say you use "Rasmus" as your author sub-directory:
        require('Rasmus/mylinetool.rb')
        This ensures the file is only loaded once.
        To load it again, regardless of whether it has been previously loaded, (say during debugging,) use:
        load('Rasmus/mylinetool.rb')
        ***** If you use double-quoted pathstrings, make sure you use slashes (/) and NOT backslashes (%(#BF0000)[]) !
        I'm not here much anymore.
          Dan Rathbun
          Your question is so basic, it marks you as a Ruby Newbie. So you need this advice:
          Ruby Newbie's Guide to Getting Started
            rvs1977
            Thank you Dan. It worked β˜€
            I have started to go through the Ruby Resource as you suggested. And I also found the answer for my own question in there. πŸ‘
            Get a Ruby
