    How to get from 3D model to 2D construction plans?
    23 Posts 7 Posters 31.5k Views 7 Watching
      Chad, you can set the camera to Parallel Projection. Look in the camera menu. Perhaps that will do what you want? another thing you can do is reduce the "wide angle" distortion by adjusting the field of view. Select the Zoom tool from the Camera toolbar. The measurements box will indicate either an angle of view or a focal length (degrees or mm). You can enter a low angle of view or a higher focal length to reduce the appearance of things receding into the distance.
      Here's an example:
      http://farm3.staticflickr.com/2427/5850582777_c4c61b6e7d_z.jpg
      28mm focal length
      http://farm3.staticflickr.com/2646/5851134266_e751b1dfff_z.jpg
      85mm focal length
        chad3006
        Yes! Switching to parallel projection did the trick. Thanks!
          Cool! πŸ‘
          • 2 / 2
