    ACT / Film and Stage Extension Strings
    3 Posts 2 Posters 331 Views 2 Watching
    • Dan RathbunD
      Dan Rathbun
      Does anyone have the strings file for the old "Film and Stage" or the newer "Advanced Camera Tools" in their " %(#8000BF)[Sketchup X/Resources/#{Sketchup.get_locale}]" directory.
      The LanguageHandler is trying to load " %(#8000BF)[adavancedcameratools.strings]" into $fs_strings but it's not happening. I don't have that file.
      I’d like to see what strings are available, before I go building my own hash.
      I'm not here much anymore.
      • D
        driven
        don't know if the encoding will cope
        // Copyright 2010 Google
        // Film and Stage extension strings
        "%.0f mm"="%.0f mm";
        "%.1f degrees"="%.1f degrees";
        "%.3f mm"="%.3f mm";
        "Alt"="Alt";
        "Aspect Ratio"="Aspect Ratio";
        "Camera Name"="Camera Name";
        "Camera Properties"="Camera Properties";
        "Camera"="Camera";
        "Cameras"="Cameras";
        "Clear the aspect ratio bars and returns to the default camera"="Clear the aspect ratio bars and returns to the default camera";
        "Create Camera"="Create Camera";
        "Creates a physical camera with real world camera parameters"="Creates a physical camera with real world camera parameters";
        "Ctrl"="Ctrl";
        "Done"="Done";
        "Edit Camera..."="Edit Camera...";
        "Film and Stage Help"="Film and Stage Help";
        "Film and Stage"="Film and Stage";
        "Focal Length = %.0f mm"="Focal Length = %.0f mm";
        "Focal length"="Focal length";
        "Format = %s"="Format = %s";
        "Height = %s"="Height = %s";
        "Height"="Height";
        "Hide %s"="Hide %s";
        "Hide Center Mark"="Hide Center Mark";
        "Hide Safe Zones"="Hide Safe Zones";
        "Hide Stats"="Hide Stats";
        "Image Width"="Image Width";
        "Look Through Camera"="Look Through Camera";
        "Looks through a camera created by 'Create Camera'"="Looks through a camera created by 'Create Camera'";
        "Name = %s"="Name = %s";
        "Name"="Name";
        "No cameras are defined."="No cameras are defined.";
        "Pan [Left-Right]/Dolly [Forward-Back]. Shift = Truck/Pedestal, %s = Pan/Tilt, Shift + %s = Zoom (Focal Length)"="Pan [Left-Right]/Dolly [Forward-Back]. Shift = Truck/Pedestal, %s = Pan/Tilt, Shift + %s = Zoom (Focal Length)";
        "Pan [Left-Right]/Tilt [Up-Down]"="Pan [Left-Right]/Tilt [Up-Down]";
        "Reset Camera"="Reset Camera";
        "Reset Tilt"="Reset Tilt";
        "Safe Zone Visibility"="Safe Zone Visibility";
        "Screen"="Screen";
        "Select Camera Type/"="Select Camera Type/";
        "Select Camera"="Select Camera";
        "Show %s"="Show %s";
        "Show all camera frustrums"="Show all camera frustrums";
        "Show all cameras created with 'Create Camera'"="Show all cameras created with 'Create Camera'";
        "Show All Cameras"="Show All Cameras";
        "Show Center Mark"="Show Center Mark";
        "Show Safe Zones"="Show Safe Zones";
        "Show Stats"="Show Stats";
        "Tilt = %.1f degrees"="Tilt = %.1f degrees";
        "Tilt"="Tilt";
        "Toggle Camera Frustrum"="Toggle Camera Frustrum";
        "Truck [Left-Right]/Pedestal [Up-Down]"="Truck [Left-Right]/Pedestal [Up-Down]";
        "Zoom (Focal Length) [Up-Down]"="Zoom (Focal Length) [Up-Down]";
        • Dan RathbunD
          Dan Rathbun
          Thanks John... seemed to paste OK into Notepad.
          I saved as UNIX EOLs, and "UTF-8 without BOM". Will try it tomarrow.
