    Tutorial: How to create physics joints in SP simulation
    1 Posts 1 Posters 1.3k Views 1 Watching
      MrDailyBlah
      Hi there..
      Now probably all of u guyz have used Sketchyphysics at some point, and created physics joints in them. πŸ˜„
      The problem though, is that sumtimes the joints become glitchy 😒 : they either become floppy or fall off completely... 😒 😠 not good...
      The solution to the problem is to create a joint while the simulation is running.
      Ever explored the scripts which make up Sketchyphysics? If so, u've probably seen the module "NewtonServer" sumwhere... πŸ˜• . this module is just about the kernel of the Sketchyphysics system. It creates nearly every physical feature of Sketchyphysics, from joints to forces to gravity and so on. πŸ€“
      We need one of its methods, which is "createJoint"...
      # this example creates a hinge joint
      parent={grp} # a grouped object that encases the joint
      child={grp} # a grouped object that is attached to the joint
      type="hinge"
      min=0
      max=0
      accel=0
      damp=0
      breakingForce=1000000
      limits=[min,max,accel,damp,0,0,breakingForce] # parameters for the joint
      xform=parent.transformation
      pinDir=xform.zaxis.to_a # the axis of the joint
      parentBody=DL;;PtrData.new(parent.get_attribute("SPOBJ","body",nil)) # converted parent body
      childBody=DL;;PtrData.new(child.get_attribute("SPOBJ","body",nil)) # converted child body
        jnt=NewtonServer.createJoint(type,xform.origin.to_a.pack("f*"),
                  pinDir.pack("f*"),
                  childBody,parentBody,
                  limits.pack("f*") ) # the joint itself
      Important: in general, all array objects need ".pack("f*")" after them, and all grouped bodies need to be converted into DL::PtrData (by using "DL::PtrData.new({grp}.get_attribute("SPOBJ","body",nil))" ) πŸ€“
      The created joint doesnt have the bugs normal joints have. (hopefully... πŸ˜† )
      Have fun "Sketchyphysic"ing (!) πŸ˜„ πŸ€“ πŸ€“ ❗ πŸ’š
