    Podium V2 interior
    72 Posts 24 Posters 12.9k Views 24 Watching
    • StinkieS Offline
      Stinkie
      The only thing missing would be the hot tub and the gold medallions πŸ’š
      πŸ’š πŸ‘
        congellous
        The set up explanation was interesting and the light around the corner is the clever bit, so is there a key light behind the camera that sounds like a good idea anyway.
        What is the QMC setting I know it's results take ages and it looks better but is there anymore tips on this, Thanks
        • soloS Offline
          solo
          Tom,
          I did not want to post here as this is a Podium thread, however I posted here: http://forums.sketchucation.com/viewtopic.php?f=81&t=43169&p=386208#p386208
          Rendered the scene with Thea bsd, then knocked out the wall and threw in some glass bricks.
          http://www.solos-art.com
          • 2 Offline
            2kemon
            Do the resulting renders from a white LEM, just outside the door, and a white sketchup background differ?
            • StinkieS Offline
              Stinkie
              Hm, I should do a comparison to find out.
              • StinkieS Offline
                Stinkie
                Thea version (TR1). Nothing too special.
                • StinkieS Offline
                  Stinkie
                  Rebuilt an Evermotion scene and rendered it with Podium. Needs plates and stuff.
                  • 2 Offline
                    2kemon
                    ...you're on to something here! Very cool indeed.
                    Did you compare the results with LEM's outside openings VS. just a white SU background?
                    • StinkieS Offline
                      Stinkie
                      Hm, no. Wouldn't be too different, I believe, from the second image, which is lit by Podium's physical sky. The main difference would be that you have less control over your lighting.
                      • marked001M Offline
                        marked001
                        you're really pushing podium to the next level here, stinkie..
                        http://www.revision21vis.com
                        instagram: revi21on
                        • StinkieS Offline
                          Stinkie
                          Thanks, Jason. There really isn't that much to it, though.
                          • StinkieS Offline
                            Stinkie
                            Mo'.
                            • 4 / 4
