    Mac Unique 'per model' ID: question
    6 Posts 2 Posters 398 Views 2 Watching
    • D
      driven
      hi all,
      I'm creating unique id's for any models, including unsaved, using
      su_Id = true
      begin
      model = Sketchup.active_model()
      su_Id = model.definitions.object_id()
      has_title = model.title()
      add_title = "Unsaved_" + su_Id.to_s
      # First check if there's an active model name
        if has_title.to_a.length == 1 then
          current_title = has_title
        else
         current_title = add_title
      rescue
         # .. handle error
         #  UI.messagebox("You need an open .skp for this to work")
          puts "You need an open .skp for this to work"
      else
      #check
          puts "model name is; " + current_title.to_s
          ensure
          puts "current_title " + "is a " + defined? current_title
          puts "Congratulations  no errors!"
      It works very well, it inside in my module, but I want use it elsewhere and don't know which bit's need to be constants or def's to use in other sub-modules.
      At this stage things go wrong when I try to wrap them.
      john
      • Dan RathbunD
        Dan Rathbun
        object_id is a Ruby integer, that is only unique within a single session. It will be reused in the next session. (The possibility exists that you may get that integer assigned to another model, in another session.)
        Sketchup already has a unique model numbering feature, that is automatically saved in the model.
        see:
        Model.guid()
        It will change if you save the model, so you'll have to track the data under the old guid, and rekey it with the new guid after saving.
        see ModelObserver#onPreSaveModel() and ModelObserver#onPostSaveModel()
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          @driven said:
          It works very well, .. but I want use it elsewhere and don't know which bit's need to be constants or def's to use in other sub-modules.
          You want to write a library submodule, that can be used by all your various other plugin submodules.
          module Driven
            module StatLib
              def self.libtask
                # method code here
              end # method def
            end # submodule Driven;;StatLib
          end # module Driven
          You would save the above file (as "statlib.rb" for example,) within your "driven" subdir, perhaps within a "lib" subsubdir.
          Then in ANOTHER file, for a plugin perhaps:
          require('driven/lib/statlib')
          module Driven
            module NiftyPlugin
              public
              def self.some_module_method
                # call your lib method
                Driven;;StatLib.libtask
                # other code here
              end # method def
              class << self
                private
                def some_private_method( arg1, arg2 )
              end # proxy class
            end # submodule Driven;;NiftyPlugin
          end # module Driven
          .. and you'd save this file in it's own plugin subdir of your "driven" dir.
          You can create local vars, module vars, or constants that just point at another module, so you can give a short "nickname" to a long qualified, multi-nested module name:
          Let's say there was some lib module, that had a class you wanted to use.
          (This is a fictious example😞
          SKX::Lib::GUI::DialogHelper::Lister
          Inside your local namespace, you can create a "nickname to it:
          ` lister = SKX::Lib::GUI::DialogHelper::Lister
          use the local pointer to call methods:
          mylist = lister.new("List of Models")`
          • Dan RathbunD
            Dan Rathbun
            Your other option is to write a special mixin module and then mixin it into your other submodules. This is a bit advanced.
            Have you read the old "Pick-Axe" Ruby book ?
            • D
              driven
              I agree, but will have another look at your other links,
              yes, and too many others, I've gone back to mainly using "Mr Neighborly's Humble Little Ruby Book" http://humblelittlerubybook.com/book/html/chapter1.html because it's 1.8.5 and most things work in mac SU.
              thanks for the comments
              john
              • D
                driven
                With this 'Untitled[0..-1] Sketchup' is always reports 'Unsaved_260629430_su.txt' until one of them is has been written to, then the number sequence randomizes.
                If I 'Save' an 'Unsaved_260629430_su.txt' the full script will (eventually) update and re-name it's file.
                I also have a cleanup sequence for closed unsaved models.
                I'll try and wrap it all, and see how it goes.
                john
