    Sketchup View origin
    12 Posts 3 Posters 2.1k Views 3 Watching
      Anton_S
      Is there a way to get Sketchup View origin relative to screen coords, through win32-api? I was searching through a bunch of functions and couldn't find it. The only good one I found was getting the origin of SU ClientArea, but not the view origin.
      • Dan RathbunD Offline
        Dan Rathbun
        What's the difference ?? The client area IS the viewport area ?
        Maybe if you post a partial screen shot, and draw dimension lines over it, we can understand what you want.
        I'm not here much anymore.
          Anton_S
          http://www.filesanywhere.com/FS/M.aspx?v=8a6d688f5a9aa7a6aa9e
          I want to get the origin of view, relative to screen coordinates
            Dan Rathbun
            Viewport:
            classname : "AfxFrameOrView80u"
            ControlType : "ControlType.Pane"
            LocalizedControlType: "pane"
            AutomationId: "59648"
              Anton_S
              @dan rathbun said:
              Viewport:
              Really interesting, what do i do with that?
                Dan Rathbun
                You were asking about making system calls.
                Use the info to find the view window. Once you have it's handle, you can request it's position on the screen.
                see this thread for examples:
                [Code] Win32 Moving/Showing/Hiding Toolbars and Dialogs
                  driven
                  This script, by Matthew Scarpino, [written initially for PC's] gives the true design window on my mac.
                  Is this what you want, or does SU-PC draw toolbars in view?
                  "Automating Sketchup" by Mat is a great book...
                  john
                  view = Sketchup.active_model.active_view
                  # Determine the size of the design window
                  h = view.vpheight.to_s;
                  w = view.vpwidth.to_s
                  # Display the window dimensions
                  puts "Window dimensions; " + w + ", " + h
                  # Display the locations of the four corners
                  puts "Upper left; " + view.corner(0)[0].to_s + ", " +
                     view.corner(0)[1].to_s
                  puts "Upper right; " + view.corner(1)[0].to_s + ", " +
                     view.corner(1)[1].to_s
                  puts "Bottom left; " + view.corner(2)[0].to_s + ", " +
                     view.corner(2)[1].to_s
                  puts "Bottom right; " + view.corner(3)[0].to_s + ", " +
                     view.corner(3)[1].to_s
                  # Find the location of the window's center
                  center = view.center
                  # Display the coordinates of the window's center
                  puts "Center; " + center[0].to_s + ", " + center[1].to_s
                  # Screen coordinates
                  origin = view.screen_coords [0,0,0]
                  puts "Origin; " + origin[0].to_f.to_s + ", " + origin[1].to_f.to_s
                  # Find out how many units a five-pixel line should take
                  size = view.pixels_to_model 50, [0, 0, 0]
                  puts "Size of a 50-pixel line at the origin; " + size.to_s
                    Anton_S
                    On Windows view.corner always return's the corners relative to view origin.
                    So, view.corner(0) always return's [0,0], view.corner(1)[0] gives the view.width, view.corner(2)[1] return's the height. View.center returns [width/2, height/2]. From these, there is no way of knowing the Sketchup view origin relative to actual, screen coords.
                    What I wan't is the Windows API or some other Function(s) that would give me the hwnd to Sketchup viewport. The Windows API Function FindWindow only works at finding the handles to the windows. It can't find the handle to a panel, button, icon or other stuff, but only to a window. Since viewport is a panel, FindWindow function wouldn't be able to get its handle.
                    If I got the handle to viewport, I could then use GetWindowRect(hwnd, rect) method to get 1st and last corners of viewport in actual screen coordinates.
                      Anton_S
                      Sketchup View is not a Window. I tried getting its handle by using function FindWindow.call(className, 0) but got 0. Then tried testing on toolbar dialogs. When toolbar was a child window (or not embeded into SU), I could get its handle, but when it was embedded into SU, FindWindow function returned 0. So, the FindWindow function doesn't works at finding handles to the panels, or 'ControllType.Pane'
                        Anton_S
                        Rightnow, I get the hwnd to viewport like that:
                        MyTool
                          def onMouseEnter(view)
                            p = 0.chr*8
                            GetCursorPos.call(p)
                            cp = p.unpack('ll')
                            @viewport_hwnd = GetWindowFromPoint.call(cp[0], cp[1])
                            rect = 0.chr*16
                            GetWindowRect.call(@viewport_hwnd, rect)
                            @viewport_rect = rect.unpack("l*")
                        Sketchup.active_model.select_tool(MyTool.new)
                        Not a good way. I would only be able to get vieport handle, once mouse enters the view.
                          Dan Rathbun
                          EVERYTHING you see on the screen, in Microsoft Windows, IS a window. A button, an edit box, a static text label, a checkbox, ... ALL of them are a window, but their style does not have a resizable frame or a caption bar, like a application window or a dialog (which are also a window.)
                          FindWindow does NOT find embedded child windows, only toplevel windows.
                          You have to get the handle for the Sketchup Application window (the parent window,) then use that in
                          view_window_handle = FindWindowEx.call(parent_window_handle,0,"AfxFrameOrView80u",0)
                          Then use GetWindowRect using the view_window_handle.
                            Anton_S
                            Thank you really much!!!, That should help!!!! πŸ˜„
