    Problems with PC
    24 Posts 5 Posters 1.7k Views 5 Watching
    • mitcorbM Offline
      mitcorb
      I am glad you got it to work.
      Your Profile and your Signature say XP?
      • Z Offline
        Zacchia
        Yes, in office where I use it most it is correct
        Problems I had at home, there I use Win7
          mac1
          Zacchia
          I would imagine you are tried of trying to get your system to work, but there is no reason why it should work some times. Maybe if you keep a list of issues and post here when you can then you have a chance of getting the total problem fixed or better yet post your issues on one of the windows 7 support forums. The reason I say either I am not sure "sometimes" implies a SU issue or windows issue. Even though you have w64 SU still runs as a 32 bit application and is still constrained to the 4GB address memory limit and all your device drivers take a bite out of that .Stating what system you have and the graphics adapter( Much better that an intergrated chip set.) would be of interest The reason I asked about the SKU version is they have differing memory size limits. I would hope you have the one that goes to 8GB because then Su has access to much more memory then when it runs on a 32 bit system.It can use 4GB, but on a 32 bit system it can only use 2 GB even if you have 4GB memory installed.( The application and kernel split the 4GB evenly) I am neglecting paging file here.
          Just some thoughts for you.
          • Z Offline
            Zacchia
            thanks mac1
            Yes my system has 8GB memory.
            • 2 / 2
