    :Dusk Render:
    7 Posts 6 Posters 776 Views 6 Watching
    • marked001M Offline
      marked001
      i think this is my first night/evening render.... this was based off of a napkin sketch from a client... its basically to show the community that they're putting a bright, clean building in a dark industrial area (disregard the fact that its a halfway house πŸ˜‰ )....
      SketchUp/Thea/Pshop...
      http://www.revision21vis.com
      instagram: revi21on
      • DanielD Offline
        Daniel
        Mmmmm...you sure do got a purty rendrin. (cue the banjo music)
        My avatar is an anachronism.
        • I Offline
          imabzeous
          how did you do that in thea.. 😞
          thre tutorials are not enough
            Roger
            The brake lights almost work, but not quite in that the perspective is not right. They are also too strong as we are seeing only the side of one brake light. They also might add some red color on the nearby wall. Maybe add some detail to the interior so it doesn't look so starkly empty. Still all-in-all a very nice render.
            http://www.azcreative.com
            • mojtabata2001M Offline
              mojtabata2001
              i like dusk renders totally
              this one is cute too
              • N Offline
                notareal
                @marked001, If you want to create light trails in Thea, you just need to animate lights (or the car with some lights in this case).
                LightTrails.pack.thea.zip
                  marked001
                  thanks guys....good advice all around.
                  i know i skimped on the interior..was hoping it would be brighter and kind of wash it all out.. too much of a rush on it as usual πŸ˜•
                  instagram: revi21on
