    ICE/FROST COVERED PLANTS
    Scheduled Pinned Locked Moved Post Processing
    2 Posts 2 Posters 8.6k Views 2 Watching
      davidh
      OK,here are 2 more tips,still in the winter theme.The first is making plants look icy/frosty.
      FROST COVERED PLANTS:
      1.open green plant and duplicate layer
      2.desaturate the copied layer
      3.Increase curves(see seting on jpg attached).This results in an almost white image.
      4.selectively erase the copied white image from the bottom up.
      BLENDING LARGE AREAS OF FOREGROUND:
      The first image shows a screensnap of a recent project.What is missing is the main snow foreground.
      1.Find a source image with the correct/similar lighting.
      2.select the part you want -but use a feathering of 20-25 in the selection so the edges are blurred.You can see in the middle image that there are elements projecting up but these can easily be hidden with vegetation.Then start copying the layer around,again selectively erasing.
      The main thing to understand with adding large areas of foreground is to feather/blur the edges.It isnt any more complicated than that.
      I will upload a new one later showing how I add individual parts of snow,such as is on the lower wall in this image.I can promise you it wont be complicated
      • EscapeArtistE Offline
        EscapeArtist
        Bookmarked!
        Great tip. πŸ‘
