    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 138.8k Views 13 Watching
      Integration Moi - Cycles teasing! 😲
      By Max Smirnov
        Ok It's working now πŸ˜„ 😎
        Cycles for Moi by Max Smirnov
        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/7429234_orig.jpg
        PS
        En VF et Manuel! πŸ˜„
          Moi Gui Builder by Chippwalters (Mac PC)
            Import poly + Subdiv by Max Smirnov becomes very cool! 😎
            http://s6.postimg.org/w9e1twq4x/oldman1.jpg
            http://s6.postimg.org/502ofep1t/oldman2.jpg
              SKetchup -->obj By Tig for free version of Sketchup
              Import OBJ --> Moi by Max Smirnov
              Export OBJ from Moi (Quad + Triangle) πŸ˜„ By Michael Gibson
              Subdiv Max Smirnov
              http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9292594_orig.jpg
              http://moiscript.weebly.com/uploads/3/9/3/8/3938813/1112342_orig.jpg
              http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9652280_orig.jpg
                By Max Smirnov!
                • JQLJ Offline
                  JQL
                  Pilou, is there some kind of Layout for MOI?
                  www.casca.pt
                  Visit us on facebook!
                    @ Jql: Not yet, maybe sizing in the V 4.0 !
                    • JQLJ Offline
                      JQL
                      I absolutely loved the way the modeling is performed on the videos you put on the thread. I can't live without the SU+LO workflow though. Even with all it's flaws, it's the best thing that happened to me since a long time.
                      MOI modelling though... is very good looking.
                      It could be a nice addition to the arsenal but I don't like switching to and from a lot of software as I like to model without a break. This MOI is really sexy but I think this might be the greatest advantage of SU over MOI or other software for me.
                      With SU (specially now with 64 bits) I can have a hub model where everything falls into place and all my needed output can be created I mean:
                      • Model with SU;
                      • Render with Thea inside SU;
                      • Walkthrough with SU;
                      • Texture creation with Gimp;
                      • Post pro with Gimp but I'm switching to Krita wich is impressive and has 16 to 32 bit support. (If I could had the normalmap maker plugin to Krita I'd ditch Gimp);
                      • And then 2D output with Layout;
                      • Nanocad just for fixing cad exports when people complain and prepare dwg for import into SU.
                      The day MOI or anyother will do all this it's the day SU starts to be questioned in my office.
                      I'll keep wanting to model that way though and I'll keep peeping at this post.
                      www.casca.pt
                        You can try also something who is between SU and Moi3D (it's free and has SKP export) πŸ˜‰
                        DesignSpark 64 Bits (who is formerly SpaceClaim light) so Sketchup on SteroΓ―ds! πŸ˜„
                        You can load Billions of Free Objects or create from zero! 😲
                        Here an Object that I have loaded then you can modify it to the infinite!
                        Then reloaded in Su after modifications! πŸ˜„
                        • JQLJ Offline
                          JQL
                          Thanks Pilou
                          I also seen you post that one. It seems very good for components that you can model independently from your sketchup model. However I really have to model most stuff inside SU as my models are architectural. It's another one wich feels like having all the right modelling tools but lack all the juice one needs.
                          It might be worth the look as it's got a very inteligent push/pull tool. I don't understand why sketchup developers don't put a greater effort towards developing existing tools. It's not that pushpull is not a cool 3D starting method, it's just that the only advanced thing you can do with it is duplicating a face (wich gets a lot of reversed face errors by the way).
                          MOI and that one really are examples to follow and I do believe that if they'd have half the popularity of Sketchup... Maybe Trimble won't let it Tremble.
                          www.casca.pt
                            Function Split by Max Smirnov
                            http://s6.postimg.org/7dyja993l/gag.gif
                              by Ed Ferguson
                              http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=e3358757e8569e8c7300d00c02fefb0c&filename=boombox4.png
                              http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=f10df25f6686331be0a0ab0ad734347a&filename=boombox1.png
                                New function Scale and Split accepts Ngons !
                                By Max Smirnov
                                A trick for the sSplit : don't select only the volume, but select the volume then use the Browser for select faces!
                                http://s6.postimg.org/5ssg9xdn5/split2.gif
                                  Teasing! πŸ˜„
                                    Split edges releaded πŸ˜‰
                                    http://moiscript.weebly.com/uploads/3/9/3/8/3938813/323333_orig.gif
                                    Knife is implicite!
                                    A simple Boolean Diff make the trick πŸ˜„
                                    http://s6.postimg.org/kp06903td/knife.gif
                                    http://s6.postimg.org/krk1vu7gx/knife1.gif
                                      new version sSplit β˜€
                                        By James Elliott
                                        http://moi3d.com/gallery/images/JamesElliotRichardIIITomb2_sized.jpg
                                        http://moi3d.com/gallery/images/JamesElliotRichardIIITomb3_sized.jpg
                                        http://moi3d.com/gallery/images/JamesElliotRichardIIITomb1_sized.jpg
                                          UI & model modèle by Chippwalters
                                          http://moiscript.weebly.com/uploads/3/9/3/8/3938813/947054949.jpg
                                          This render inside Sketchup with free Visualizer 1.3!
                                          http://dl.dropboxusercontent.com/u/3788438/3D/VIZ_0016a.jpg
                                          http://dl.dropboxusercontent.com/u/3788438/3D/Env2-01.8.jpg
                                          http://dl.dropboxusercontent.com/u/3788438/3D/ProductRender03.55.jpg
                                            Shoes Tutorial
                                            by Lawrence
                                            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/5595950_orig.jpg
                                            Mannequin By Chippwalters
                                            File 3DM File SKP linked! πŸ˜‰
                                            http://s6.postimg.org/916pwfx3l/mannequin_su.jpg
                                            https://dl.dropboxusercontent.com/u/3788438/MoIGUIdownloads/MOI-PAT/MOI-PAT.001.jpg
                                            mannequin.skp
                                            • 6
                                            • 10
                                            • 11
                                            • 4 / 11
