    Sketchy Physics help :O
    9 Posts 5 Posters 10.7k Views 5 Watching
    • E Offline
      enard
      Hello.. just a quick question... sorry im fairly new to sketchy physics.
      Every time I try to name the "controller" it gives me an error that I dont know what to do about, and then
      it ends up not even renaming the part. 😕 😕
      Any help would be appreciated, Thanks!
      the error goes as such:
                                       Formula doesn`t compile:
                                       "the name I put in for controller"
                                       "A list of codes an so on"
        DanYHKim
        If you're renaming the controller through the (forget what it's called. The UI button on the toolbar), you can't delete the entire name given in the dialog box. You can only change the name that is inside brackets and quote marks:
        controllername1234("controllername1234")
        becomes
        controllername1234("NewNameForControl")
        If I misunderstood you, please forgive me.
        • E Offline
          enard
          becomes
          well when you select a hinge for example, and you open the UI(SketchyPhysics Inspector) the "controller" box is empty, it is highlited in blue though but when i enter a name then for the first time, thats when it gives me that error! kinda confused here lolz...
            DanYHKim
            AAahhhh! The hinge joint has no controller, since it does not actually have any power. You want a "servo" joint, which is designed to be rotated around one complete turn. If you want it to spin, use a "motor".
            Similarly, a slider joint probably has no controller, while a piston does.
            • E Offline
              enard
              unforunately it gives me the exact same error on the servos or motors or anything 😲
              i dont know if it might be cause i need a newer version of sketchy?
              i got sketchup 7 with sketchy 3.....
              • H Offline
                hpnisse
                Hello!
                You can do the controller-thing in diffrent ways:
                Write this in the controller field.
                slider("NAMEofSLIDER")
                When you press play there will be a slider in a box, from value 0 to 1, (it will start on 0.5)
                key("SOMEkey")
                If you change "SOMEkey" to "W" for example, then when you press "W" it will be the same as the slider put to 1 (one)
                getVar("SomeText")
                This is used when you will programming the model to do diffrent stuffs, it´s a little more difficult to explain.
                hope this will work it out for you!
                /hpnisse
                ` /hpnisse`
                ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
                  tspco
                  hpnisse, I have a question for you, well maybe more than that.
                  I have be using sp for about a month, I managed to make things work using examples I have found online, but nothing definitive.
                  My first question, I have an elevator in a model it is set for 132" and -132" or something like that. When I start the animation the slider goes to 0.5, as with other silder operated stuff. When I start the animation, the elevator moves to halfway up, so I have to use the slider to move it back down, I would prefer, that it stayed down until I wanted it to move. Same thing for a ramp on a vehicle, I want the ramp to stay in the "up", position until I wanted to lower it. How do I make this happen? or can I make this happen?
                  SU make 2017, /Twilight Render Hobby
                  Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                  • H Offline
                    hpnisse
                    Hello!!
                    I don´t know really how to do that fully functional.
                    But you can change so the value always start at 0 (zero), but the slider will be in the middle as always.
                    **Go to this folder that contain the physics files: Standard: "C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\SketchyPhysics3"
                    Then open the "ControllerCommands.rb" file with a text editor or something like that! (ex. notepad in Windows)
                    Scroll down to line "11", probably you don´t have to scroll.
                    The line: def slider(sname,defaultValue=0.5,min=0.0,max=1.0)#command#
                    Change the line to: def slider(sname,defaultValue=0.0,min=0.0,max=1.0)#command#
                    Then save and restart Sketchup!
                    When you create a slider or motor or anything at all right now, with a slider, and then start it will show 0.0 and nothing will move.
                    !BUT the slider itself will be at the middle of the line! Don´t touch it yet!
                    Press pause and pull down the sliders to zero, then it will work!**
                    /hope this will solve the problem, otherwise, I recommend that you learn to script with "RUBY".
                    Perhaps we can help you with the basics, if I get time! Otherwise, I recommend this website!
                    ` /hpnisse`
                      stefanocarloni
                      I have the same problem! 😞
                      The dialog box is blue, and I can't write anything, it says me: "Script Error:
                      uninitialized constant MSketchyPhysics3::ControllerContext::Main".
