    UI programming
    5 Posts 2 Posters 648 Views 2 Watching
      tspco
      No one will probably answer, but I will try yet again.
      I have a servo, controlled by (leftx)that part works good, but when I run the simulation the part I am moving goes to halfway. I want it to start at 0 (straight out horizontal) in a 0-60 range. I tried a couple of things in the UI but I have had no success.
      Ideas?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • Chris FullmerC Offline
        πŸ˜†
        Good luck Ryan!
        All my Plugins I've written
          tspco
          Thanks for the answer Chris, so I was wrong, someone did answer, just not the answer I was hoping for. I love SketchyPhysics, most of the time the things I make work as expected. If I had a "manual" to go from I would revise it and make a thorough user guide. But just pokin' and hopin', ain't workin'.
            Is the sketchyphysics code scrambled - could you theoretically read it to understand how it works?
              tspco
              I might be able to figure it out, if I had a place to start, mainly I am interested in making, my models do different stuff. I have played around enough to have a basic understanding of the UI, but it's very basic. Things like rightx and righty I can figure out, but things like
              -rightx-righty+1, it works but why? and whats the +1 all about?
              A place to start would be like what commands there are, and how are they used. There is zero documentation on this kind of stuff that I can find.
