    Moving objects
    2 Posts 2 Posters 513 Views 2 Watching
      Derek mason
      I want to move a box down a packing line and send it at 90 degrees at the end. I can send it down the line but how do i make it change direction and keep moving
        mptak
        Push works well. Something like this inside the Sketchy Physics UI for the object.
        xpos=0.0
        ypos=0.0
        xturn=150.0
        yturn=150.0
        ontick{
        if frame%60 == 0
            if xpos < xturn || ypos > yturn
              push([1,0,0])
              puts ("pushx")
            else
              push([0,2,0])
              puts ("pushy")
            xpos=position().x
            ypos=position().y
            puts(ypos)
        This will push towards the x direction for awhile then push towards the y and then back to the x. You could also change the logic so the push direction changed based on touching the bumpers using the ontouch event.
        downtrack.skp
