    Loft model
    8 Posts 7 Posters 2.3k Views 7 Watching
    • AdamBA Offline
      AdamB
      Inspired by the beautiful image posted by Speaker the other day (http://forums.sketchucation.com/viewtopic.php?f=333&t=41281), I had a go recreating the model in SketchUp.
      Lighting time for both is under 3 minutes, images straight out of LightUp.
      http://i614.photobucket.com/albums/tt229/ElektraGlide/loftNighttime_2011-11-16_1120.jpg
      http://i614.photobucket.com/albums/tt229/ElektraGlide/loftDAY_2011-11-16_1113.jpg
        dsarchs
        At a guess that's not an R-60 roof. 😉
        Looks good, although the angle really shows the tiling of the brick texture.
        Knowledge is a polite word for dead but not buried imagination.
        -e.e.cummings
        • FrederikF Offline
          Frederik
          Looks great, Adam... 👍
          LightUp sure looks like it's capable of generating better photo realistic renders...
          Haven't had a chance of trying the new version - yet... 😐
          So question is, once rendered are you able to maintain the photo real effect when orbiting the scene/model...?
          My understanding of LightUp is/was that it bakes the lightning into textures...
          Cheers
          Kim Frederik
          • soloS Offline
            solo
            looking sweet!
            Hmmm, thinking if I could use Lightup with Lumion for light maps.
            http://www.solos-art.com
            • artysmediaA Offline
              artysmedia
              I'm interested about the answer of this question! 😲 Baked textures!? If it is true, i like it!
              Interesting render, but i don't like the brick repetition also ☀
              Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
              Blog: Artysmedia
              • AdamBA Offline
                AdamB
                Thanks everyone.
                LightUp bakes "view independent" lighting offline, and calculates "view dependent" effects in realtime.
                That essentially means diffuse light effects are calculated once and cached, and specular effects are calculated on the GPU. This allows unlimited numbers of lights with shadows while still having 30 frames/second motion.
                Here's a realtime capture of SketchUp running LightUp - but the youtube vid has dropped the frame rate from its normal 30 frames/sec 😞
                [flash=800,600:3mj7y6fe]http://www.youtube.com/v/czBsvJ_cG_k[/flash:3mj7y6fe]
                  Speaker
                  Here is the actual model in Lightup 😄
                  http://i.imgur.com/hKlov.jpg
                  And a short animation of it.
                  http://www.youtube.com/watch?v=rdVy3r1uLt4
                  Lightup really has improved a lot since the early releases 👍
                  http://www.youtube.com/user/latvietis1234
                  • tibetT Offline
                    tibet
                    hi adam,
                    wow, that´s an incredible job!
                    lightup is such a powerful tool .
                    is there any way how to change character of any object to give it eg. a glow apperiance? ( like neon sign and so on )
                    i wonder if there any tool compared to it.
                    i´ve heard someone mentioned UNITY 3D, but didn´t tried by myself.
                    good luck!
                    http://i52.tinypic.com/zujcp1.jpg
                    SU 2015 Pro on Win10 x64
