    And so it begins or continues
    3 Posts 2 Posters 389 Views 2 Watching
      tspco
      Here is a video I made using SU, SP, and recorded with the SP "frame recorder". Since camera follow, and camera track, still don't work like they should, I tried to keep the model in the screen, but I wandered off screen a couple of times.3
      Enjoy
      [flash=420,315:1micorih]http://www.youtube.com/v/TrFm-d-rDO0?rel=0[/flash:1micorih]
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
      • mitcorbM Offline
        mitcorb
        Good work, tspco:
        I salute you for your tenacity. The off cameras are not so bad.
        I misread the machine's name momentarily. It looked like "snore over" not to be mistaken with "voice over", but similar. hee hee.
        EDIT: You are way ahead of me.
          tspco
          Maybe I should have written the name like this Sno-Rover, as in a rover for snow (removal). 😉
          The following is a comment not necessarily connected with the post above. (it is an ADD thing).
          Articulated vehicles seem to work better than those with steerable wheels. It seems the servos are to weak. It has to do with the perceived mass of the object they are connected to, or so I read somewhere. It sure seems to be correct.
