    Another "watercolour" from render
    7 Posts 6 Posters 693 Views 6 Watching
    • PixeroP Offline
      Pixero
      Here's another NPR watercolor style image I did in Photoshop from a render of mine.
      Original was around 5000 pixels wide.
      • marked001M Offline
        marked001
        beautiful, Jan... i like this one alot.. what was your basic workflow in pshop?
        http://www.revision21vis.com
        instagram: revi21on
          turbobrad
          Wonderful Jan.
          BradE
          Dean3Design
            Landie
            I'm a big fan of your work Jan, and this piece is full of all the stuff I like....texture, pared back detail, fade to the distance and subtle colour tinting. The only thing I'd like to see is the same line work you've got on the building applied to the path, hedges, tree parts etc. For me the line work binds it all together. I'd also just crop a bit off the bottom as you have the third vanishing point in play.
            http://www.smithdimes.co.uk
            • jarynzlesaJ Offline
              jarynzlesa
              another great job πŸ‘
              yes, please πŸ˜„
              http://www.vizualizaceschodiste.mypage.cz/
              • PixeroP Offline
                Pixero
                Thanks for your comments.
                I was thinking maybe to write a tutorial but no promises as to when it will be done.
                • michaliszissiouM Offline
                  michaliszissiou
                  It's beautiful
                  Yeah, a tutorial, but I can also assume some past involvement with art. he he
                  Which happens to be the most important.
                  Here we have a clear vision of the architectural work, in a way that no physically correct render can produce. Just notice the play between these figures and the trees. This exactly projects the scale of these buildings. The scale in a more philosophical manner. A script.
                  Some crits. The girl (bubbles), should look much closer to camera but let's not make it more difficult for the clients πŸ˜†
