    Parameter passing across two files
    3 Posts 2 Posters 274 Views 2 Watching
    • C
      Chris88
      Hello,
      can somebody say how to pass a parameter across two files in ruby?
      To be exact it's a variable, which contains a string.
      The string changes its value at the runtime.
      Is there a problem with sketchup?
      Thank you.
      • Dan RathbunD
        Dan Rathbun
        file: "chris88/chris88_mod.rb"
        module Chris88
          @@common_var_name = "some string value"
          # create a getter method for @@common_var_name
          def self.common_var_name()
            return @@common_var_name
          end #def method
        end #module
        file: "chris88/plugin_one.rb"
        require("chris88/chris88_mod.rb")
        module Chris88;;PluginOne
          local_var_name = Chris88.common_var_name()
          # local_var_name is pointing at the SAME string object that
          #  Chris88;;@@common_var_name is also pointing at.
          # If you wish a copy then;
          local_var_copy = Chris88.common_var_name().dup
        end #module
        file: "chris88/plugin_two.rb"
        module Chris88;;PluginTwo
          puts( "The value of my common string is; #{Chris88.common_var_name()}" )
        end #module
        I'm not here much anymore.
        • C
          Chris88
          Great!
          Thank you Dan.
