    Exportvertices2csv.rb as a teaching material
    5 Posts 3 Posters 585 Views 3 Watching
    • T
      tetsuyahishida
      I'm now studying Ruby Code and using TIG's
      "exportvertices2csv"as a teaching material.
      I think TIG is putting all the code in initialize,in order to make the code simple.
      Although I know that is a wise way. I'm now practicing to rapping it in instance method.
      In order to devide it in to "initialize part" and "outputting csv part"
      I've wrote these code.
      =begin
      (c) TIG 2011
      Type
        Exportvertices2csv.new
      in the Ruby Console.
      Exports all Vertices is a Selection to a X,Y,Z 'CSV' file.
      Edit sep="," if something other than a separating comma is desired e.g. ';'
      Make sep="\t" if a TSV file is desired and change ext="csv" to ext="tsv".
      It uses the current Model Units/accuracy with the approximate '~ ' and
      unit suffix [if any] removed; e.g. change Model Units to 'meters' 3dp to
      get exported csv in meters 1.234 - don't use 'fraction' 1' 2 1/2" formats,
      always use a 'decimal' format.
      1.0 20110105 First issue.
      1.1 20110116 Wrapped in protective class.
      =end
      require 'sketchup.rb'
      class Exportvertices2csv
      def printcsv(verts)
          pts=[]
          verts.each{|v|pts << v.position.x.to_s.gsub(/^~ /,'').to_f.to_s+sep+v.position.y.to_s.gsub(/^~ /,'').to_f.to_s+sep+v.position.z.to_s.gsub(/^~ /,'').to_f.to_s}
          model=Sketchup.active_model
          path=model.path
          if not path or path==""
            path=Dir.pwd
            title="Untitled"
          else
            path=File.dirname(path)
            title=model.title
          end#if
          ofile=File.join(path,title+'_verts.'+ext).tr("\\","/")
          begin
            file=File.new(ofile,"w")
          rescue### trap if open
            UI.messagebox("Vertices File;\n\n  "+ofile+"\n\nCannot be written - it's probably already open.\nClose it and try making it again...\n\nExiting...")
          return nil
          pts.each{|pt|file.puts(pt)}
          file.close
          puts (pts.length.to_s)+" vertices written to\n"+ofile
          begin
            UI.openURL("file;/"+ofile)
          rescue
      end#def
      def initialize()
          sep="," ### <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
          ext="csv" ### <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
          ss=model.selection
          verts=[]
          ss.each{|e|verts << e.vertices if e.class==Sketchup;;Face or e.class==Sketchup;;Edge}
          if not verts
            UI.messagebox("No Vertices were Selected.\nExiting.")
      	  return nil
          end#if
          verts.flatten!.uniq!
          self.printcsv(verts)
      end #def
      end#class
      but recieve this error message.
      Error: #<NoMethodError: undefined method `printcsv' for #Array:0xde0858c>
      does someone have any idea?
      Sincerely yours
      • Chris FullmerC
        line 58
        change to
        printcsv(verts)
        my head can't think this through though, and it might need to be
        Exportvertices2csv.printcsv(verts)
        So try one of those, or maybe someone else will come through and help refine my answer 😳
        All my Plugins I've written
        • Dan RathbunD
          Dan Rathbun
          line 53 ( verts is not a boolean object.)
          Should be: if verts.empty?
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            @chris fullmer said:
            line 58
            change to
            printcsv(verts)
            Correct Chris. The method is an instance method.
            BUT.. this code is a perfect example of something that should be a module, and not a class.
            • T
              tetsuyahishida
              Thankyou all!
              The problem was solved.
              Dan Rathbun
              Do you mean the whole class "Exportvertices2csv"
              should be a module?
              Or, the instance method "printcsv"should be a module?
