    Color the DC conditioning on its attributes & values (MYSQL
    23 Posts 4 Posters 1.5k Views 4 Watching
      blue_orchid
      UI.menu("Plugins").add_item('Assessment') { Jeny.color }
      module Jeny
          def self.color
      require 'mysql'
      dbh = Mysql.real_connect("localhost", "root", "...", "test",3306)
      dbh.query("drop table if exists inspection")
      dbh.query("create table inspection(component varchar(20), ID int(4), rating int(1))")
      dbh.query("insert into inspection values('deck',2345,1),('Substructure',2349,2),('Superstructure',2353,3)")
      printf "%d rows were inserted\n",dbh.affected_rows
      res = dbh.query("SELECT id, rating FROM inspection")
      while row = res.fetch_row do
      a=row[0]
      b=row[1]
      c=row[2]
      printf "%s, %s, %s\n", a, b, c
      puts a.inspect
      puts b.inspect
      puts c.inspect
       Sketchup.active_model.entities.to_a.each{|e|
               if e.get_attribute('dynamic_attributes','id','')=="2345"||(b=='2345') || (c=='1')
      then e.material = 'red'
                if e.get_attribute('dynamic_attributes','id','')=="2345"||(b=='2345') || (c=='2')
      then e.material = 'yellow'
      In the above code, what I did....
      color the DC
      which has attribute 'ID' = 2345
      b==2345 ( b=id from database)
      c=1(c=rating in database)
      with red color.
      And similarly Dc
      c=2 (c=rating in database)
      with yellow color.
      Problem is that
      1.it accepts only the last code, so it changes the object to yellow color not to red color.
      I even tried using 'case and when' control structure
      for example
      %(#4000FF)[Sketchup.active_model.entities.to_a.each{|e|
      case e.get_attribute('dynamic_attributes','id','')=="2345"
      when b=='2345' || c=='1'
      then e.material = 'green'
      end }]
      But it didn't work...
      Can anyone tell me what the appropriate control structure is?
      • Chris FullmerC Offline
        Hey Blue Orchid, I've moved this post to the "Developers Forum" (like I did you're previous one as well).
        You'll get much more response by the people who regularly check that forum, than the regular SketchUp forum.
        Looks like your making progress on your script. You need to write a tutorial on how to integrate MySQL into SU when you get a chance - even better would be MySQL-Lite (well, I think).
        Good luck,
        Chris
        All my Plugins I've written
        • jolranJ Offline
          jolran
          %(#FF0000)[Sketchup.active_model.entities.to_a.each{|e|
          if e.get_attribute]
          Don't know if there is some speciality in your script, but must not you define |e| ?
          Like: if e. is kind of? Sketchup::Someentity OR if e.class Sketchup::SomeentityAnd the put the arguments/conditionals..
          Just guessing.. Could be different in your case...
          • Dan RathbunD Offline
            Dan Rathbun
            @jolran said:
            ... but must not you define |e| ?
            Joel, That IS, in fact, the declaration of local variables to the block, within the " |" delimeters.
            The each method automatically passes the iterator into the block, referenced by the var defined ( e in this case.)
            @Jeny... outdenting makes your code very hard to read. All blocks should indented.
            I'm not here much anymore.
              Dan Rathbun
              for example
              end }]
              Your use of case is wrong.
              The case clause declares the "object" to use FOR comparison (on the right of a === operator,) but not the comparison(s) themselves.
              The while clauses declare the value that goes on the left of a === operator.
              More like:
                this = e.get_attribute('dynamic_attributes','id','')
                case this
                when '1','37','89'
                when '2345'
                when '' # empty
                  e.material = 'orange'
                else
                  e.material = 'blue'
                Dan Rathbun
                Jeny, the coloring should go inside your while block that fetches each record from the database.
                Also, you can speed things up by
                ents = Sketchup.active_model.entities.to_a
                and then use the ref ents until anything is added or deleted from the model.
                You can also narrow down ents to only elements that are DCs:
                ents.reject! {|e|
                   e.class!=Sketchup;;ComponentInstance ||
                   e.definition.attribute_dictionary('dynamic_attributes').nil?
                • jolranJ Offline
                  jolran
                  Oh yeah that's true, Dan. 😳
                  I missread the codeblock..
                    blue_orchid
                    Dan, can you show me how to use while block for coloring?
                      Dan Rathbun
                      No. You would not learn anything if I did your work for you.. and I wouldn't get paid.
                        blue_orchid
                        while (c=='1'){
                        e.get_attribute('dynamic_attributes','id','') == "2345"
                            end}}
                        Dan, I know it's not the correct way to write the code as it failed. I tried.
                          Dan Rathbun
                          Try something like this:
                          # put requires outside the module
                          require('sketchup.rb')
                          require('mysql')
                          module Jeny
                            def self.colorize
                              colors = ['black','red','yellow','green']
                              printf( "%d rows were inserted\n",dbh.affected_rows )
                              # remove non-DCs
                              ents.reject! {|e|
                                 e.class != Sketchup;;ComponentInstance ||
                              ents.each{|e|
                                eid = e.get_attribute('dynamic_attributes','id','')
                                unless eid.empty?
                                  found = nil
                                  found = # lookup row in dB with field id == eid
                                  if found
                                    e.material = colors[ found[2] ]
                                end #unless
                              # close dB connection !!
                            end #def
                          end # module Jeny
                          unless file_loaded?(File.basename(__FILE__))
                            UI.menu("Plugins").add_item('Assessment') { Jeny.colorize }
                            file_loaded(File.basename(__FILE__))
                          and read this:
                          Ruby Newbie's Guide to Getting Started
                            blue_orchid
                            Dan,
                            I used the script that you have written.
                            No color change in the components.
                              Are the components already colored? Or are the internal faces colored already?
                                Dan Rathbun
                                @blue_orchid said:
                                Dan, I used the script that you have written.
                                Did you finish line 32 ??
                                and replace line 39 ?
                                I am not a SQL person, so I cannot test it for you.
                                http://rubydoc.info/gems/mysql/2.8.1/frames
                                  blue_orchid
                                  Chris,
                                  components are colored with ruby script. I did not the paint the component with any color in the sketchup itself.
                                  I hope i answered your question.
                                  I also tried the same script in the components which don't have any color. But it didn't work.
                                    blue_orchid
                                    Dan, I am sorry that I did not understand your question?
                                      Dan Rathbun
                                      replace line 39 with:
                                      dbh.close()
                                      line 32 is NOT complete.
                                      YOU need to finish it so it looks up a record in res
                                      It's a example, I have no way to test it myself.
                                        blue_orchid
                                        UI.menu("Plugins").add_item('Assessmenteww') { Jeny.color }
                                        module Jeny
                                        def self.color
                                        require 'mysql'
                                        dbh = Mysql.real_connect("localhost", "root", "orange", "test",3306)
                                        #printf "%d rows were inserted\n",dbh.affected_rows
                                        #while row = res.fetch_row do
                                        #a=row[0]
                                        #b=row[1]
                                        #c=row[2]
                                        #printf "%s, %s, %s\n", a, b, c
                                        #end
                                        #puts a.inspect
                                        #puts b.inspect
                                        #puts c.inspect
                                        this = e.get_attribute('dynamic_attributes','id','') == "2345"
                                        case this
                                        when res == '2345' && '1'
                                        e.material = 'red'
                                        when res == '2349' && '2'
                                        e.material == 'green'
                                        when res == '3'
                                        e.material == 'blue'
                                        when '' # empty
                                        else
                                        %(#40BF00)[Sketchup.active_model.entities.to_a.each{|e|
                                        case this
                                        e.material = 'red'
                                        when res == '3'
                                        when '' # empty
                                        else
                                        When I run this script, the component with id '2345' does not change its color, but the other component changes its color to red. Why is this so?
                                          Dan Rathbun
                                          You still do not understand how to use the case statement, your better off using a if .. elsif .. else .. end block.
                                          And.. once again your coloring is after the iteration of the dB (outside the while block,) so your only going to be acting upon the LAST record from the dB.
                                          How experienced are you at:
                                          Ruby?
                                          SQL databases?
                                          Experience using any other programming languages?
                                            blue_orchid
                                            i am not at all experienced in any programming language and mysql. Ruby is my first programming language. I have gone through several ruby guide, but still i am having hard time learning it and working on it.
                                            i am just doing it for a project and i am really having a hard time doing it.
                                            • 1 / 2
