    Color the DC conditioning on its attributes & values (MYSQL
    23 Posts 4 Posters 1.9k Views 4 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @jolran said:
      ... but must not you define |e| ?
      Joel, That IS, in fact, the declaration of local variables to the block, within the " |" delimeters.
      The each method automatically passes the iterator into the block, referenced by the var defined ( e in this case.)
      @Jeny... outdenting makes your code very hard to read. All blocks should indented.
      I'm not here much anymore.
        Dan Rathbun
        @blue_orchid said:
        I even tried using 'case and when' control structure
        for example
        %(#4000FF)[Sketchup.active_model.entities.to_a.each{|e|
        case e.get_attribute('dynamic_attributes','id','')=="2345"
        when b=='2345' || c=='1'
        then e.material = 'green'
        end }]
        But it didn't work...
        Can anyone tell me what the appropriate control structure is?
        Your use of case is wrong.
        The case clause declares the "object" to use FOR comparison (on the right of a === operator,) but not the comparison(s) themselves.
        The while clauses declare the value that goes on the left of a === operator.
        More like:
          this = e.get_attribute('dynamic_attributes','id','')
          case this
          when '1','37','89'
            e.material = 'yellow'
          when '2345'
          when '' # empty
            e.material = 'orange'
          else
            e.material = 'blue'
          Dan Rathbun
          Jeny, the coloring should go inside your while block that fetches each record from the database.
          Also, you can speed things up by
          ents = Sketchup.active_model.entities.to_a
          and then use the ref ents until anything is added or deleted from the model.
          You can also narrow down ents to only elements that are DCs:
          ents.reject! {|e|
             e.class!=Sketchup;;ComponentInstance ||
             e.definition.attribute_dictionary('dynamic_attributes').nil?
          • jolranJ Offline
            jolran
            Oh yeah that's true, Dan. 😳
            I missread the codeblock..
              blue_orchid
              Dan, can you show me how to use while block for coloring?
                Dan Rathbun
                No. You would not learn anything if I did your work for you.. and I wouldn't get paid.
                  blue_orchid
                  while (c=='1'){
                  e.get_attribute('dynamic_attributes','id','') == "2345"
                      end}}
                  Dan, I know it's not the correct way to write the code as it failed. I tried.
                    Dan Rathbun
                    Try something like this:
                    # put requires outside the module
                    require('sketchup.rb')
                    require('mysql')
                    module Jeny
                      def self.colorize
                        colors = ['black','red','yellow','green']
                        dbh = Mysql.real_connect("localhost", "root", "...", "test",3306)
                        dbh.query("drop table if exists inspection")
                        dbh.query("create table inspection(component varchar(20), ID int(4), rating int(1))")
                        dbh.query("insert into inspection values('deck',2345,1),('Substructure',2349,2),('Superstructure',2353,3)")
                        printf( "%d rows were inserted\n",dbh.affected_rows )
                        res = dbh.query("SELECT id, rating FROM inspection")
                        # remove non-DCs
                        ents.reject! {|e|
                           e.class != Sketchup;;ComponentInstance ||
                        ents.each{|e|
                          eid = e.get_attribute('dynamic_attributes','id','')
                          unless eid.empty?
                            found = nil
                            found = # lookup row in dB with field id == eid
                            if found
                              e.material = colors[ found[2] ]
                          end #unless
                        # close dB connection !!
                      end #def
                    end # module Jeny
                    unless file_loaded?(File.basename(__FILE__))
                      UI.menu("Plugins").add_item('Assessment') { Jeny.colorize }
                      file_loaded(File.basename(__FILE__))
                    and read this:
                    Ruby Newbie's Guide to Getting Started
                      blue_orchid
                      Dan,
                      I used the script that you have written.
                      No color change in the components.
                      • Chris FullmerC Offline
                        Are the components already colored? Or are the internal faces colored already?
                          Dan Rathbun
                          @blue_orchid said:
                          Dan, I used the script that you have written.
                          Did you finish line 32 ??
                          and replace line 39 ?
                          I am not a SQL person, so I cannot test it for you.
                          http://rubydoc.info/gems/mysql/2.8.1/frames
                            blue_orchid
                            Chris,
                            components are colored with ruby script. I did not the paint the component with any color in the sketchup itself.
                            I hope i answered your question.
                            I also tried the same script in the components which don't have any color. But it didn't work.
                              blue_orchid
                              Dan, I am sorry that I did not understand your question?
                                Dan Rathbun
                                replace line 39 with:
                                dbh.close()
                                line 32 is NOT complete.
                                YOU need to finish it so it looks up a record in res
                                It's a example, I have no way to test it myself.
                                  blue_orchid
                                  UI.menu("Plugins").add_item('Assessmenteww') { Jeny.color }
                                  module Jeny
                                  def self.color
                                  require 'mysql'
                                  dbh = Mysql.real_connect("localhost", "root", "orange", "test",3306)
                                  #printf "%d rows were inserted\n",dbh.affected_rows
                                  #while row = res.fetch_row do
                                  #a=row[0]
                                  #b=row[1]
                                  #c=row[2]
                                  #printf "%s, %s, %s\n", a, b, c
                                  #end
                                  #puts a.inspect
                                  #puts b.inspect
                                  #puts c.inspect
                                  this = e.get_attribute('dynamic_attributes','id','') == "2345"
                                  case this
                                  when res == '2345' && '1'
                                  e.material = 'red'
                                  when res == '2349' && '2'
                                  e.material == 'green'
                                  when res == '3'
                                  e.material == 'blue'
                                  when '' # empty
                                  else
                                  %(#40BF00)[Sketchup.active_model.entities.to_a.each{|e|
                                  case this
                                  e.material = 'red'
                                  when res == '3'
                                  when '' # empty
                                  else
                                  When I run this script, the component with id '2345' does not change its color, but the other component changes its color to red. Why is this so?
                                    Dan Rathbun
                                    You still do not understand how to use the case statement, your better off using a if .. elsif .. else .. end block.
                                    And.. once again your coloring is after the iteration of the dB (outside the while block,) so your only going to be acting upon the LAST record from the dB.
                                    How experienced are you at:
                                    Ruby?
                                    SQL databases?
                                    Experience using any other programming languages?
                                      blue_orchid
                                      i am not at all experienced in any programming language and mysql. Ruby is my first programming language. I have gone through several ruby guide, but still i am having hard time learning it and working on it.
                                      i am just doing it for a project and i am really having a hard time doing it.
                                        Dan Rathbun
                                        Yes it shows. You will need to study and re-read the tutorials again and again, until it sinks into your brain.
                                        You should read the 'Pick-Axe' book cover to cover.
                                        http://www.phrogz.net/ProgrammingRuby/frameset.html
                                          blue_orchid
                                          UI.menu("Plugins").add_item('Assesment') { Jeny.color }
                                          require 'mysql'
                                          module Jeny
                                              def self.color
                                          #res = dbh.query("SELECT rating, id FROM inspection")
                                          res = dbh.query("SELECT rating FROM inspection where id = '2345'")
                                          xx = row[0]
                                          printf "%s\n", xx
                                          res1 = dbh.query("SELECT rating FROM inspection where id = '2349'")
                                          while row = res1.fetch_row do
                                          xy = row[0]
                                          printf "%s\n", xy
                                          res2 = dbh.query("SELECT rating FROM inspection where id = '2353'")
                                          while row = res2.fetch_row do
                                          yy = row[0]
                                          printf "%s\n", yy
                                          if e.get_attribute('dynamic_attributes','id','2345')
                                          e.set_attribute('dynamic_attributes','rating','xx')
                                          if e.get_attribute('dynamic_attributes','id','')== "2349"
                                          e.set_attribute('dynamic_attributes','rating','xy')
                                          if e.get_attribute('dynamic_attributes','id','') == "2353"
                                          e.set_attribute('dynamic_attributes','rating','yy')
                                          if e.get_attribute('dynamic_attributes','id','2345') && xx == "1"
                                               e.set_attribute( 'dynamic_attributes', 'material', 'red')
                                               e.set_attribute( 'dynamic_attributes', '_material_formula', '"red"')
                                               $dc_observers.get_latest_class.redraw_with_undo(e)
                                          elsif e.get_attribute('dynamic_attributes','id','2345') && xx == "2"
                                               e.set_attribute( 'dynamic_attributes', 'material', 'blue')
                                               e.set_attribute( 'dynamic_attributes', '_material_formula', '"blue"')
                                          elsif e.get_attribute('dynamic_attributes','id','2349') && xx == "3"
                                               e.set_attribute( 'dynamic_attributes', 'material', 'green')
                                               e.set_attribute( 'dynamic_attributes', '_material_formula', '"green"')
                                          if e.get_attribute('dynamic_attributes','id','2349') && xy == "1"
                                          elsif e.get_attribute('dynamic_attributes','id','2349') && xy == "2"
                                          elsif e.get_attribute('dynamic_attributes','id','2349') && xy == "3"
                                          if e.get_attribute('dynamic_attributes','id','2353') && yy == "1"
                                          elsif e.get_attribute('dynamic_attributes','id','2353') && yy == "2"
                                          elsif e.get_attribute('dynamic_attributes','id','2353') && yy == "3"
                                          %(#BF4000)[What I did here:
                                          I set attribute 'rating' for different objects with different names like xx, xy and yy.
                                          Then I made these attributes 'ratings' equal to result from query for each component/object.
                                          Finally i selected the color for each component and different values of ratings a color.
                                          But it still selects only last code i.e. objects color change to green . May be it could not identify the Db values.]
                                          Now what i want to do that if the rating for a component is 1 in database, then the attribute 'rating' for that component is changed to 1 using DB value. Is it possible?
                                            blue_orchid
                                            This code finally worked πŸ˜„
                                            UI.menu("Plugins").add_item('Assesment') { Inspection.color }
                                            require 'mysql'
                                            module Inspection
                                                def self.color
                                            		dbh = Mysql.real_connect("localhost", "root", "***", "test",3306)
                                            		dbh.query("insert into inspection values('deck',2345,2),('Substructure',2349,1),('Superstructure',2353,3)")
                                            		xx = row[0]
                                            		printf "%s\n", xx
                                            		xy = row[0]
                                            		printf "%s\n", xy
                                            		yy = row[0]
                                            		printf "%s\n", yy
                                            			if e.get_attribute('dynamic_attributes','id','')=='2345'&& xx=='1'
                                            			e.set_attribute('dynamic_attributes','rating','1')
                                            			elsif e.get_attribute('dynamic_attributes','id','')=='2345'&& xx=='2'
                                            			e.set_attribute('dynamic_attributes','rating','2')
                                            			elsif e.get_attribute('dynamic_attributes','id','')=='2345'&& xx=='3'
                                            			e.set_attribute('dynamic_attributes','rating','3')
                                            			if e.get_attribute('dynamic_attributes','id','')=='2349'&& xy=='1'
                                            			elsif e.get_attribute('dynamic_attributes','id','')=='2349'&& xy=='2'
                                            			elsif e.get_attribute('dynamic_attributes','id','')=='2349'&& xy=='3'
                                            			if e.get_attribute('dynamic_attributes','id','')=='2353'&& yy=='1'
                                            			elsif e.get_attribute('dynamic_attributes','id','')=='2353'&& yy=='2'
                                            			elsif e.get_attribute('dynamic_attributes','id','')=='2353'&& yy=='3'
                                            			if e.get_attribute('dynamic_attributes','rating','')=='1'
                                            			e.set_attribute( 'dynamic_attributes', 'material', 'black')
                                            			e.set_attribute( 'dynamic_attributes', '_material_formula', '"black"')
                                            			elsif e.get_attribute('dynamic_attributes','rating','')=='2'
                                            			elsif e.get_attribute('dynamic_attributes','rating','')=='3'
                                            Thanks to all.
