    Requires sketchyphysics3.2
    3 Posts 2 Posters 1.2k Views 2 Watching
    • P
      physicsman
      Hi everybody,
      Impossible to install V3.2 ?
      the v3.1 is still installed when you download the last version, no update possible and impossible to use the joint connector.
      Please need fedbacks,
      • P
        physicsman
        I tried to install the V3.1. And now when I click on joint connector, I still get a message in the top left corner of the SU display "Requires SketchyPhysics 3.1".
        I use Xp Pro SP2 and SU 8.
        SP is very impressive and suit to my need, I don't want to forgive!! Please may I have one comment ?
        Many thanks
        • 6
          6677
          @physicsman said:
          Many thanks
          The message isn't a warning to you. its a warning to other downloaders that they will need sketchyphysics 3.1 to run the model. You will be able to run the sim fine.
          The message is useful however, double click it and you can edit it to include the instructions to use your model.
