    [Code] wrapping operations
    5 Posts 4 Posters 2.6k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      ALWAYS use a begin .. rescue .. end block for your operation.
      If an error occurs, the operation can be aborted, and (hopefully,) prevent corruption of the model.
      begin
        op_name = "My Operation"
        model.start_operation( op_name )
          ### indented code statements here
        model.commit_operation
      rescue => e
        model.abort_operation
        puts("Error #<#{e.class.name};#{e.message}.>")
        puts(e.backtrace) if $VERBOSE
      else
        # Do code here ONLY if NO errors occur.
      ensure
        # ALWAYS do code here errors or not.
      I'm not here much anymore.
      • jolranJ
        jolran
        Thanks.
        /Joel
        • F
          Francis Mc Shane
          Dan,
          thanks for this. It works. I don't know why though!
          Best,
          Francis
          • Dan RathbunD
            Dan Rathbun
            @francis mc shane said:
            Dan,
            http://ruby-doc.org/core-2.0.0/doc/syntax/exceptions_rdoc.html
            Ya should probably read the docs on page
            http://ruby-doc.org/core-2.0.0/index.html
            from "doc/syntax.rdoc" on down. There is only 11.
            • M
              MSP_Greg
              One can also wrap Dan's code in a method
              def self.operation(opName, procElse = nil, procEnsure = nil)
                if (block_given? && String === opName)
                  am = Sketchup.active_model
                  begin
                    am.start_operation(opName, true)
                    yield
                    am.commit_operation
                  rescue => e
                    am.abort_operation
                    puts("Error operation block #<#{e.class.name};#{e.message}.>")
                  else
                    procElse.call()   if (Proc === procElse)
                  ensure
                    procEnsure.call() if (Proc === procEnsure)
                else
                  raise "Error operation parameters - No block given or opName not a String!"
              # call by
              # operation("My operation") { operation block }
              Note that if either procElse and procEnsure are used, they should probably be lambdas. One should also be careful about return statements in the block passed to the method.
              BTW, I'll use snake case for methods, maybe not variables...
              Greg
