Vodin
Vodin 1902-04
John
Haha... You have decided to model all Voysey's houses. Mind you it could be quite good material for some sort of digital book on Voysey. I was wondering are you actually modelling interiors as well. I know it could be hard to aquire true info but maybe worth exploring in your case.
I like the quality of your models. All bits including flashing are corret and read true. The only crit for render I have is a bit of slate repetion on the roof and maybe more clouds in the sky as render shows pretty overcast day. But this is really nitpicking as render and especially model as well are great. -
I love the model! I've tried doing some like this myself but get confused on how to place the model into the background scene. Is it a photo match thing or something else?
Thanks Kurt
Hello sepo, thanks for your comments. I don't intend to do interiors of these. The roof is quite a size to texture with good results, a little more PS needed maybe.
Hello kurt, I hope the two images below help explain the process I used.
regards John
Register LoginAdvertisement
