πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[REQ] Component array formerly Triangular array
27 Posts 7 Posters 3.1k Views 7 Watching
    sdmitch
    justo, try this plugin, I think it will do what you want.
    Plugin can be found at
    http://forums.sketchucation.com/viewtopic.php?f=323&t=40244
    results tor Triangular Array.rb
    http://sdmitch.blogspot.com/
      sdmitch
      @justo said:
      :sketchstatic:
      Would I be painful if I was to ask if the angle could be selectable so it could be set for 45deg and 0 deg, just so all the arrays are in one spot? (Im looking at the script and dont understand any of it to try to do it myself)
      Thanks everyone for your input!
      Added angle input and 3d capability so face can be tilted.
      Not sure what you mean.
        sdmitch
        One plugin to rule them all.
        'Array plugin' which has the Triangular, Rectangular, and Rectangular on 45deg (or defineable angle) arrays.
        Possible?
        Sure.
          jolran
          Well yeah.! But Chris F's Components onto Faces already does that function, so...
          Obviously you are a very talented programmer, so in my opinion it's a little waste for you to do something does already exist. Or might exist in next versions of thoose plugins.
            sdmitch
            Well I don't know all that exists. I simply see a request and try to offer a solution. If Chris has a plugin that does this then it is no doubt better than mine I would suggest you use it.
              jolran
              No, you are right. That did not exist exactley.
              What I ment was you did not go to that trouble for my sake. Now that you have. I'm greatful πŸ˜„ .
              Thanks.
                Justo
                Adam ended up doing a 0.5 instead of 2... i think thats what you meant? or did i get my x/y's the wrong way... πŸ˜‰
                pt0.offset!(ya,interval*0.5)
                either got it
                I'll post further questions to the plugin page πŸ˜’
                Cheers
                Justin
                • 2 / 2
                2 / 2
