    Trace what prevents an object from being GC'd?
    22 Posts 4 Posters 2.0k Views 4 Watching
      Is there a way to trace back the references of an object in some manner? Finding the cause to why an object isn't garbage collected.
      I've used ObjectSpace to inspect the count, where I've noticed some objects aren't GC'd. And after trying to set all references I know of to nil - they still aren't GC'd.
      • tbdT Offline
        tbd
        several solutions:
        • patch ruby vm - https://gist.github.com/73674
        • memproof gem - http://timetobleed.com/memprof-a-ruby-level-memory-profiler/ (Linux x64 only)
        • ripping the internals via debugger 😉 - http://www.coffeepowered.net/2010/08/23/debugging-memory-leaks-in-ruby-with-gdb-round-2/
        does it eat a lot memory ?
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
          theee... I don't have an overview of that. ...I know... don't optimize what doesn't need to be, but it bothers me that I don't know why.
          It's a subclasses WebDialog, where a WebDialog will normally GC, my subclassed version doesn't. So everytime I create one, it lingers about. (how much memory usage, I'd expect depends on the HTML content.)
          (another odd thing about WebDialogs, when I create one, a normal one, ObjectSpace's count increased by two... 😕
          • Dan RathbunD Offline
            Dan Rathbun
            I remember AdamB posting about this in another thread last year (or so,)....
            .. anyway. The "hidden" reference is held by the C++ as the object is a MFC window object (on PC,) and in ObjectiveC (on Mac,) as an NSWindow object.
            I'm not here much anymore.
              Dan Rathbun
              It does occur to me that we do not have a call to tell the Sketchup C++ engine that we are done with a WebDialog instance and want it "disposed of".
              We would need an .dispose() instance method for the UI::WebDialog class, that would tell the C++ engine to get rid of it's reference (and then sets the receiver on the Ruby-side to nil [if that's possible.])
              Then you can get rid of your class definition using remove_const(:MyWebDialogSubclass)
                The thing is, a normal WebDialog instance will be GC'd if you clear all references to it.
                But there is something I have done in my subclass that prevents this - and I'm not finding out why.. 😞
                  Dan Rathbun
                  Sure.. as I remember Adam's post .. I thot he showed they were not GC'd.. but is was awhile back.
                  It could be nothing more exotic than that Google did not account for us subclassing UI::WebDialog, similar to the way some API methods only accept exact classes and not any subclasses.
                    Dan Rathbun
                    Did you dispose of all Locals, Constants, instance vars, and perhaps maybe even Procs that are within your subclass?
                      Maybe... I was planning on trying a simple subclass - without all the stuff I have in mine. Just to see if that makes the differences.
                      You could test the GC of a WebDialog if you like - so we can compare results.
                      I did a count of the existing WebDialogs, then created a new one. Made a new count ( +2 in my results ) then I set my references to the WD to nil and invoke GC.start. The count then went down by 2. Confirm?
                        I set all local variables to nil, nothing to the constants - just strings.
                          Dan Rathbun
                          @thomthom said:
                          You could test the GC of a WebDialog if you like - so we can compare results. ... Confirm?
                          OK, here:
                          dlg = UI;;WebDialog.new
                          >> #<UI;;WebDialog;0x61dc79c>
                          ObjectSpace.each_object(UI;;WebDialog) {}
                          >> 2
                          dlg=nil
                          >> nil
                          >> 2
                          GC.start
                          >> nil
                          >> 0
                          MyDialog = Class.new(UI;;WebDialog)
                          >> MyDialog
                          MyDialog.superclass
                          >> UI;;WebDialog
                          dlg=MyDialog.new
                          >> #<MyDialog;0x6071ed4>
                          >> 2
                          ObjectSpace.each_object(MyDialog) {}
                          >> 2
                          dlg=nil
                          >> nil
                          >> 2
                          >> 2
                          GC.start
                          >> nil
                          >> 0
                          >> 0
                            Dan Rathbun
                            But I did not show() the dialog in the previous test, so:
                            dlg=MyDialog.new('Test')
                            >> #<MyDialog;0x61d2f30>
                            dlg.show
                            >> true
                            # empty dialog with title 'Test' is displayed,
                            # .. and I close it manually.
                            >> 2
                            >> 2
                            dlg=nil
                            >> nil
                            >> 2
                            >> 2
                            GC.start
                            >> nil
                            >> 0
                            >> 0
                              Dan Rathbun
                              Are you testing on PC (v1.8.6-p287) or Mac (v1.8.5-p0) ??
                              I guess I should say that I'm running:
                              RUBY_VERSION 1.8.7 RUBY_PATCHLEVEL 299
                              .. get I set it for a test and forgot to set it back.
                                Dan Rathbun
                                @ThomThom...
                                look at this example:
                                https://gist.github.com/355820
                                A the bottom he determines that there is a finalizer that is holding a ref to the instance, and therefor the reason why the instance is not getting GC'd.
                                I know you were trying to use a finalizer to cleanup a temp file.. likely that's the culprit.
                                  @dan rathbun said:
                                  @ThomThom...
                                  Not in this case. I'm testing on SU8, default Ruby. I've used finalizer, but it only triggers under OSX. And I've read the gotchas about finalizers not GC'ing - and implemented it so it doesn't hold a reference.
                                  However, I think I'm somehow creating a reference somewhere... I just can't track it down...
                                    It seems to be due to using self.add_action_callback within the initialize method of the subclass.
                                    <span class="syntaxdefault">class WC </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> def initialize</span><span class="syntaxkeyword">(*</span><span class="syntaxdefault">args</span><span class="syntaxkeyword">);</span><span class="syntaxdefault"> super</span><span class="syntaxkeyword">;</span><span class="syntaxdefault"> self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_action_callback</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'test'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">diag</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">param</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> puts diag</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> param </span><span class="syntaxkeyword">};</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">;</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">;<br /></span><span class="syntaxdefault">nil<br /><br />ObjectSpace</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_object</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">WC</span><span class="syntaxkeyword">){}<br /></span><span class="syntaxdefault">0<br /><br />x</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">WC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">new </span><span class="syntaxstring">'test'<br /></span><span class="syntaxcomment">#<WC;0x18dc1000><br /><br /></span><span class="syntaxdefault">ObjectSpace</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_object</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">WC</span><span class="syntaxkeyword">){}<br /></span><span class="syntaxdefault">2<br /><br />x</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">nil<br />nil<br /><br />GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />nil<br /><br />ObjectSpace</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_object</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">WC</span><span class="syntaxkeyword">){}<br /></span><span class="syntaxdefault">2<br /></span>
                                    When I use add_action_callback outside initialize it does get GC'd.
                                    <span class="syntaxdefault">ObjectSpace</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_object</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">){}<br /></span><span class="syntaxdefault">2<br /><br />wd</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">new </span><span class="syntaxstring">'test'<br /></span><span class="syntaxcomment">#<UI;;WebDialog;0x18f1a2a8><br /><br /></span><span class="syntaxdefault">ObjectSpace</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_object</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">){}<br /></span><span class="syntaxdefault">4<br /><br />wd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_action_callback</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'test'</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">diag</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">param</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> puts diag</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> param </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">true<br /><br />wd </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil<br />nil<br /><br />GC</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />nil<br /><br />ObjectSpace</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each_object</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">WebDialog</span><span class="syntaxkeyword">){}<br /></span><span class="syntaxdefault">2<br /></span>
                                    I don't understand why...
                                      Dan Rathbun
                                      Oh.. that's an easy one: Because **self** IS a reference to THE instance.
                                      So YOUR telling Ruby to keep 'literal' reference within the code.
                                      You dont need that reference by the way.. because the initialize method ALWAYS gets executed WITHIN the newly created instance, just after the class constructor (usually new,) creates it.
                                      So just remove the " self." from in front of ALL instance method calls made from within ANY of the object's instance methods.
                                      • Chris FullmerC Offline
                                        Interesting, 👍
                                        All my Plugins I've written
                                          I had a suspicion that might be it, and it's what I had planned to try next. But I still don't understand why. As self.add_action_callback is just calling a method, never is self being stored in any reference... ❓
                                            Removing self. from add_action_callback made no difference.
                                            • 1 / 2
