    Back face/material reverse
    24 Posts 5 Posters 1.6k Views 5 Watching
      jan_pamplona
      pls help me, back color face issue,
      if we make a simple rectangle or a plane, i think the default is that the "face" facing you turns into a front color automatically, right!?
      But now im having a problem with that, when i try to make a plane , the face that's facing me always turns into a back color,
      I don't know if there's something i clicked or changed somewhere in settings but i dont know what that is
      i got so irritated on right clicking the face and selecting "reverse face", it takes me a lot of time,
      HOW DO I GET THAT DEFAULT SETTINGS BACK?
      A big thanks f u could help me..
      • Dan RathbunD Offline
        Dan Rathbun
        NO... it does not have anything to do with "facing YOU".
        When you draw a face, it's normal (The direction the front surface is facing,) is always toward the negative axis.
        But the PushPull tool will reverse the face if it needs to do so.
        I'm not here much anymore.
          Dan beat me (with some slightly different explanation but similar results):
          The normal behaviour of SU is that if you draw a 2D shape on the red/green plane ("ground plane"), it will always show a back face top. The reason is that SU supposes that it will be the bottom of a 3D shape and in that case, the front face should be directed "outside", at the bottom of that 3D shape.
          Even the PushPull tool is programmed to take this into consideration and when you start to PP such a face, it will reverse it (and when starting to PP, for a moment, you can even see the Z-fighting between the original face and a newly created, reversed face).
            jan_pamplona
            Thank you very much sir,,
            yeah, i remember now, im so dumb :,) it's just that i forgot those things because im drawing 2D plans and not noticing about the Push/Pull,thanks
            • 2 / 2
