    Window handle from process
    37 Posts 5 Posters 4.5k Views 5 Watching
      Alienizer
      getWindow                = Win32API.new('user32.dll', 'GetWindow', 'li', 'l')
      getTopWindow             = Win32API.new('user32.dll', 'GetTopWindow', 'l', 'l')
      getWindowThreadProcessId = Win32API.new('user32.dll', 'GetWindowThreadProcessId', 'lp', 'l')
      getCurrentThreadId       = Win32API.new("kernel32.dll", "GetCurrentThreadId", '', 'L')
      tid = getCurrentThreadId.call
      wnd = getTopWindow.call(0)
      pid = 0.chr * 4
      while wnd != 0
      	getWindowThreadProcessId.call(wnd, pid)
      	pidnum = pid.unpack('L').first
      	if pidnum == tid
      		UI.messagebox(wnd.to_s)
      		break
      	wnd = getWindow.call(wnd, 2)
      I'm trying to get the Sketchup window handle, and my code above never gets to display the handle! Looks right to me, but I have no idea why it isn't working. Any ideas?
      I'm from Mars and moved to Earth to alienize you. Unfortunately, I became humanized.
        Have a look at this thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=33756&p=296865#p296865
        Note I posted one simple method that works only if the SketchUp window has focus, and one that should work regardless.
          Alienizer
          Yes I did look at your post first, but I got mixed results, sometimes SK just unload from memory, and sometimes the handle was nil. So I wanted to created one without a callback, hence my code above. I'm just not sure what the bug is.
            Alienizer
            model_path = Sketchup.active_model.path
            if (model_path.empty?)
             	model_name = "Untitled"
            else
              model_name = File.basename(model_path)
            if (Sketchup.app_name == "Google SketchUp Pro")
              sketchup_title = model_name + " - SketchUp Pro"
            else
              sketchup_title = model_name + " - SketchUp"
            findWindow = Win32API.new("user32.dll", "FindWindow", ['P','P'], 'N')
            window_id = findWindow.call(0, sketchup_title)
            Here's another way that works, but it's based on the title. I'd rather have my first one working instead, or your's if SK doesn't crash.
            Have you tried my first one see what you get? Do you see what's wrong with it?
              Did you try using GetAncestor.call(handle, GA_ROOTOWNER) to ensure you get the root SketchUp window which is the owner of all SU's window? Your code might be getting a child window...
                > else
                > end
                > else
                > end
                What if the user has multiple windows open with the same title? Multiple unsaved models etc?
                  @alienizer said:
                  sometimes SK just unload from memory.
                  You experienced crashes?
                    Alienizer
                    No I didn't, because my code never return a handle to begin with! It does iterate all windows, so it should pickup the pid, that's why I'm asking for help!
                      Alienizer
                      I know, that's why I don't want to use it and want my first code to work!
                        Alienizer
                        Yes, and it seems to have something to do with toolbars from 3rd party. When I have all of them visible (about 30 of them), your code runs for about 10 secs then SK unload from memory!
                        • Dan RathbunD Offline
                          Dan Rathbun
                          From Ruby you can get process id, like:
                          or
                          Process.pid
                          I'm not here much anymore.
                            Alienizer
                            or
                            Process.pid
                            That worked 👍 I should have used GetCurrentProcessId instead of GetCurrentThreadId 😒 but your way is much simpler. Thanks!
                              Dan Rathbun
                              Using "Untitled" as a substring only works in English editions.
                              In other editions it's bound to be a unicode string.
                              The Win32 Resource ID in the sketchup.exe String Table is 61443 (in case you like using a LoadString system call.)
                                Alienizer
                                True!
                                Thanks.
                                But I don't think my approach or that of thomthom to get the SKP window works. If you use Process.pid and enum the windows until you find the right one, and use GetWindowText WinAPI to get the title of the SKP window, it works, but not always. I have a shortcut to SKP in one of my folder and it works to get the title, but if I use the Windows Start menu to run SKP, the title is blank, so it's not getting the proper window as expected. And since the return text is blank, we can't tell which window it is!
                                So try it using the following...
                                wnd = getAncestor.call(wnd, 3)
                                buf = "\0" * 260
                                getWindowText.call(wnd, buf, 256)
                                UI.messagebox(buf.strip)
                                or the complete code...
                                getWindowText = Win32API.new('user32', 'GetWindowText', 'LPI', 'I')
                                getAncestor = Win32API.new('user32', 'GetAncestor', 'LI', 'L')
                                tid = Process.pid
                                pid = 0.chr * 4
                                while wnd != 0
                                   if pidnum == tid
                                			buf = "\0" * 260
                                      break
                                  Alienizer
                                  I found the answer to my own problem! I was running the code inside my class
                                  I don't know why it makes a difference!
                                    Dan Rathbun
                                    You should always be running your wrapped within a module.
                                    The problem with TopWindow is that if a user has wxSU installed, the Sketchup window will be wrapped in a WX::Frame, and wxSU resets the Sketchup app window to have the invisible frame as it's parent.
                                    There are other quirky title things. If a user double clicks a SKP file to start Sketchup, the Title will not have "Untitled" (in the local language,) but could have a filename with unicode characters, and if it's Sketchup Pro, there's a bug where it does not have the "Pro" part until after it finishes processing the Plugins and Tools folders, and draws to UI (toolbars and menus.)
                                    I rejected this window title approach as too problematic:
                                      #  find_skp_hwnd_by_title(debug=false)
                                      #  Try to find app window by title.
                                      #  Highly modified from wxSU code.
                                      def find_skp_hwnd_by_title(debug=false)
                                        require('Win32API.so')
                                        skp_window_id = 0
                                        # Set locale specific "Untitled" string Hash
                                        # ** this won't work as is because some strings are unicode
                                        notitle = Hash.new("Untitled")
                                        notitle['cs'] = "Názvu"           # Czech
                                        notitle['de'] = "Unbenannt"       # German
                                        notitle['en'] = "Untitled"        # English
                                        notitle['en-US'] = "Untitled"     # English
                                        notitle['es'] = "Sin título"      # Spanish
                                        notitle['fr'] = "Sans titre"      # French
                                        notitle['it'] = "Senza titolo"    # Italian
                                        notitle['nl'] = "Titelloze"       # Dutch
                                        notitle['pl'] = "Niezatytulowane" # Polish
                                        notitle['pt-BR'] = "Sem título"   # Portuguese-Brazil
                                        notitle['pt'] = "Sem título"      # Portuguese
                                        notitle['tr'] = "Basliksiz"       # Turkish
                                        # These strings are reportedly not translated
                                        sketchup_free = "SketchUp"
                                        sketchup_pro = "SketchUp Pro"
                                        no_license = "[LICENSE UNAVAILABLE]"
                                        # Find the SketchUp main window handle by its window title
                                          model_name = notitle[ Sketchup.get_locale ]
                                          if (Sketchup.app_name == "Google SketchUp")
                                            sketchup_title = model_name + " - " + sketchup_free
                                          else
                                            sketchup_title = model_name + " - " + sketchup_pro
                                        else
                                          # For some reason, when starting SketchUp Pro by double-clicking an SKP
                                          #   file, the window title says SketchUp until after load is complete.
                                        skp_window_id = findWindow.call(0, sketchup_title)
                                        if debug && skp_window_id == 0
                                          msg = "Sketchup Window could NOT be found with title;\n #{sketchup_title}"
                                          msg<< "\n\nWill search for No license version.\nClick OK to continue..."
                                          UI.messagebox(msg)
                                        else
                                          UI.messagebox("Sketchup Window found with title; #{sketchup_title}")
                                        if (skp_window_id == 0)
                                          # Can't find the window, look for no license version
                                          skp_window_id = findWindow.call(0, sketchup_title + " " + no_license)
                                            UI.messagebox("Sketchup Window could NOT be found with title; #{sketchup_title}")
                                          else
                                        return skp_window_id
                                      end # def
                                      Alienizer
                                      I agree 100% with you.
                                      BTW, when SKP runs your rb scripts, is the rb script first compiled by the Ruby interpreter, or is it interpreted like the old DOS Basic? Or compiled to P-Code?
                                        Dan Rathbun
                                        Well it's not called a "compiler" is it?
                                          Alienizer
                                          😆 No, but I doubt it interprets characaters by characters at run time, it would be too slow. It has to pre-compile or something.
                                            Dan Rathbun
                                            Well the actual Ruby Core modules, classes and methods, are themselves compiled C-functions.
                                            The interpreter just "gathers" the arguments from the plain text scripts, and makes the C calls in the background.
                                            If you have downloaded the Ruby C source... you can read the interpreter's source to get an idea of what's happening behind the scenes.
                                            • 1 / 2
