    Uv c++ and sketchup
    1 Posts 1 Posters 349 Views 1 Watching
    • G
      giuseppe500
      hello.
      I 'm creating a shetchup importer ,that use a texture atlas .
      I'm a beginner and i wouldn't go inside the jungle of wrap/tile of texture atlas custom shaders.
      my problem now is to recognize what are wrapped/tiled and what are not for process without atlas the tiled/wrapped textures.
      I'm creating this function in c++:
      bool CMesh;;IsTiled()
              std;;vector<TEXCOORD*>;;iterator itBegin =      m_vTextureCoord.begin();
              std;;vector<TEXCOORD*>;;iterator itEnd =        m_vTextureCoord.end();
              for(;itBegin != itEnd; itBegin++)
                      if(abs((*itBegin)->U) >1 || abs((*itBegin)->V) >1)
                      return true;
              if(m_pMaterial->GetTypeMaterial() == eTextureDouble){
                      std;;vector<TEXCOORD*>;;iterator itBegin =      m_vTextureCoordBack.begin();
                      std;;vector<TEXCOORD*>;;iterator itEnd =        m_vTextureCoordBack.end();
                              return true;
              return false;
      but i see that this is wrong:
      i removed the abs():
      if( ((*itBegin)->U) >1 || ((*itBegin)->U) <0)
      return true;//is tiled/wrapped
      the problem is that i have some texture UV of U = -0.4 V = 0.2 and with a simple atlas algorithm it work fine !
      why?
      the texture UV don't be from 0 to 1 ?
      this is the code for read from sketchup api the uv:
              m_pApi->ImportVertexUV(&fu, &fv, &fw, &fub, &fvb, &fqb);
              TEXCOORD *ptUV = new TEXCOORD;
              ptUV->U = fu  ;
              ptUV->V = 1- fv ;//this is added from me without explanations , only
      for ;"so 'works"  BAD!!!!
              ptUV->W = fw;
              vVectorUV.push_back(ptUV);
      //ecc...
      //ecc...
      how i can recognize uv and wrapped texture?
      I heard that sketchup does not normalizes the coordinates uv, is it possible?
      how do I normalizing if this is the problem?
      thanks.
