    Cannot install SP3.2 in OS X 10.6
    4 Posts 3 Posters 1.1k Views 3 Watching
      MichaelG.1
      As a new member, first please accept my apologies if this has already been answered elsewhere.
      Having upgraded to SketchUp v8 Pro, I waited for the release of SP 3.2 before attempting to install SketchyPhysics. Unfortunately, I have failed.
      I have downloaded 3.2 from http://code.google.com/p/sketchyphysics/downloads/list
      and copied it across to the plugins folder, but nothing appears in SketchUp.
      Could some experienced user please advise?
      Many thanks
      MichaelG.
        adyall
        Michael how exactly did you solve this problem? I have the identical one. I placed the downloaded folder into the plugins folder under /Library/Application Support/Google SketchUp 8/SketchUp, then restarted SU but cannot see the toolbar. I've looked for it under view>tool palettes
        Thanks,
        Andrew
          Hi Gys (and Michael, it seems you did not get an answer...).
          We have a dedicated SP subforum under the Extensions Forum. I will move this topic there.
          I do not use SP but maybe you need to activate it under SketchUp > Preferences > Extensions?
            MichaelG.1
            Thanks,
            Andrew
            Andrew,
            Sorry for the delay in replying
            I'm pretty sure that my original download was damaged or incomplete, so ...
            First I trashed all trace of the first attempt, and then emptied the Trash.
            Then I downloaded again, and copied the unzipped items into place.
            ... after which [as they say] "it just worked".
            N.B.
            1: it seems to be essential that the plugins folder is in the tree starting "Macintosh HD" not the one starting at your home folder. i.e. under DEVICES not under PLACES
            2: you need to copy across everything that unzips ... the "loose" files as well as the folder.
            Hope that helps.
            MichaelG.
